Re: 72 johnson 50hp
Hi Karl....The needles in the carbs were for low end or idle adjustments. The setting on each needle being done separately with the engine in the water and in gear, motor at operating temp.<br /><br />Now, these older motors were not really noted for their gas efficency.....are you experiencing fouled plugs and such? A little more info would be a start. Also, is the engine running at operating temp?
