Re: 1976 evinrude 9.9
Eula30, I'm sorry to hear you had so much trouble but it's what I expected after your first pic. That darn aluminium oxide grabs onto those bolts like nothing else. Coat them in sealer and it won't happen next time.<br /><br />Normally to cut threads you use a tool called a 'Tap', as in a 'Tap and Die' set. If you've had no experience using one, I strongly suggest you try on some scrap aluminium first. The taps are very brittle and if you break one off taping new holes, you'll be in bigger trouble.<br /><br />If I understand you correctly, you've drilled out to the 'inside' size of the bolts' thread and want to tap new threads to accept the same sized bolt as was in there before. Am I correct in that?<br /><br />If not, you have two choices: tap for a larger bolt or install a heli-coil. The heli-coil is the better route as it allows you to put things back to 'stock' with superior threads then the original. And you won't run into bolt-head size problems. Plus, the heli-coil kit comes with it's own tap, so you won't have to purchase a set, just a tap wrench.
