90 hsp Johnson Outboard idle problem
SethR
Hello, I have a 90 hsp Johnson (mid 80'S). I recently put new throttle cables and a new starter on it. But now when I start it, it idles for awhile then starts to rev up, even when I DO NOTHING. Is this an easy fix? If so... How?
Solittle
Re: 90 hsp Johnson Outboard idle problem
Welcome Seth - Was it doing this before you worked on it?<br /><br />Suggest that you go to the main page & hop to the engine FAQ section. There are some great posts on troubleshooting.<br /><br />Do you have a shop manual?
SethR
Hello, thanks for the reply...<br />No it was not doing this before and Yes I do have a shop manual, (and you would think it would say something about this... huh). I don't know much about boat engines, but I know I don't want to blow the ****ing thing up! And thats what it sounds like after it idles for a moment. Any ideas?
rodbolt
hello<br /> double check the trunion is adjusted so when the control returned to the idle position the linkage is pulled back to the throttle stop. its the large screw with a spring and a nut that the screw comes to a bracket mounted on the block.
ob
I agree.If it was idling right before replacing cables ,somethings out of adjustment.Insure the carburetor/s linkage roller is on center and "just touching" the scribe line of the throttle cam when controls are in the neutral position.
