Mark, Welcome to iboats.!
Running better with the choke partially engaged, usually points to a fuel delivery problem. If pumping the primer bulb does not improve the running issue, it probably time for a carb cleaning-rebuild. Carb rebuild kits are cheap, and with the help from a service manual, and easy task to install. If pumping the primer bulb does improve the idle-running, then this points to the fuel pump. As you have already figured out, the tank vent must be open, otherwise, the fuel pump can't draw fuel from the tank ( draws a vacuum from the tank).
