what is the difference
sunbeam2
I have a 1994 Evinrude 8 hp 2 stroke and I need a powerpack for it.<br />I also have a 1987 Johnson 8 hp 2 stroke that sorta runs and I want to know if I can use the same power pack for both engines???<br /><br />If not what is the diff between the power packs?
walleyehed
Re: what is the difference
This could be wrong, but my parts book doesn't show a powerpack for an '87 8HP...matter of fact, it doesn't show an 8HP in 1987 period...????
rabidfish
BRP Part # 586800 for the 1987 and the 1994<br /><br />from 1989 to 1992 it was the UFI ( under the flywheel ignition )
sunbeam2
My local dealer is telling me that the 1987 8hp needs part #586691 and the 1994 8hp motor needs part # 586800 what is the diff the two power packs look exactly alike
marinemech
probably polarity one is positive the other negative
rodbolt
Originally posted by Rabidfish:<br /> BRP Part # 586800 for the 1987 and the 1994<br /><br />from 1989 to 1992 it was the UFI ( under the flywheel ignition )
that is the difference
rabidfish
My 2005 P & A book show them the same, as does the quick ref. chart.<br /><br />My Partsmart show what your dealer does.<br />Nearly as I can tell, the difference is rev limit.<br /><br />Joe Reeves is bouncing around here today, he might well have an answer!
OBJ
Interesting......<br /><br />PartSmart (2005) shows the 87' pn as 586691 and the 94' as 586800.....both superceeded numbers. Now the really funny thing is that the 6hp of both years superceeds to 586800...same as the 94' 8hp. Don't have the P&A book but Rabidfish says they are the same.......I dunno.
rodbolt
sunbeam<br /> if both packs mount on the side, carfully inspect the wire colors at the connectors. the connectors are labeled A,B,C,D and sometimes E. some packs had a seperate wire for kill. other than some packs had SLOW ( I dont think the 8 ever did) most of the changes were in the rev limiter. if you already have the pack and the wire colors match give it a try. the input voltages are about the same as are the outputs.
Joe Reeves
The 1987 8hp model was/is 8RCU & 8RLCU. As "Rodbolt" states above in his reply/post, the 1989 model incorporates the powerpack etc "under" the flywheel. The 1987 model incorporates a external powerpack.<br /><br />Those two (above) obviously will not interchange.<br /><br />Being retired, I do not have the 1994 book. However, it's quite unlikely that the engineers back tracked and returned the powerpack to being an external one.<br /><br />Bottom line.... The external and internal modules will not interchange.
rabidfish
Tommorrow, I'll contact BRP tech support.<br /><br />I'll return an answer then...
rabidfish
The partsmart shows #586691.<br />This is the power pack alone.<br /><br />The quick reference chart and the 2005 P & A book both show the #586800.<br />This is a kit that has(besides the 586691), several different connectors, boots, etc... to convert almost any 2 cylinder to the current power pack.<br /><br />The UFI power pack is a completly different animal alltogether... They still make it for parts, but the engine have been back to using the external pack since 1994
