Honing a three-cylinder block
AVAST
Hello, my question is, I honed the cylinder enough to de-glaze the walls, but still have small marks at top of cylinder. Should I hone them out or will they be okay? Number one cylinder was top to bottom, 3.00, 3.002, 2.999. Number two was 3.00, 3.00, 3.001. Number three was 3.001, 3.001, 3.001. This is a 1980 evinrude, 70 hp, which broke a crank on number one rod bearing. :(
ob
Re: Honing a three-cylinder block
Ahoy,AVAST,I don't like the taper on #1.That plus visible scoring.Honing more will just make it worse.May consider going oversize.
AVAST
There is no vertical scoring marks in cylinders, but there is a small horizontal line at the ridge. Tried to send a picture of block, but couldn't figure out how.
Laddies
Banned
It's all but impossible to true cyls. with a convention hone, you should use a precision hone, as you can see by your own measurments you have made it worse. No more honeing it should run. the reason you have a ring at the top of the cyl. is because you did not use a ridge reamer before honeing.
