  #1
Old May 13th, 2005, 07:04 PM
MadeCoolCom MadeCoolCom is offline
Default Steering cable Evinrude 60 hp 1980
Evinrude 60 hp 1980 I believe on a 16 V bottom heavy boat.I have to replace the steering. I notice that the sleeve or pipe on the engine that the steering cable goes intois bad rusted. Also some help. Do I replace that also or just clean it up- if there is a way to clean this pipe up how? I see some rust inside.The steering cable I took out today and I notice it about 13' 7" long it has a gear on the end by the steering wheel.Also some help. Where the best place to get this cable?
  #2
Old May 13th, 2005, 08:19 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: Steering cable Evinrude 60 hp 1980
If the steering tube is really rusted up bad, consider replacing it with a stainless tube. Most marine shops can help out with that.Is the "gear" a long gear? Or is it mounted in the helm....under the dash? Check the link below to iboats Mall. They carry cables and complete steering systems. http://www.iboats.com/mall/index.cgi...31&submit.y=10
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old May 13th, 2005, 08:40 PM
Thanks OBJIt looks a little like the one at the link here http://www.iboats.com/mall/index.cgi...**=03613 7163 accept I can not see the gear in this picture. But my gear was only about 4 inches.It looks like this one will work.What I wanted to do was keep my old steering wheel and the gear on the end and just connect the new cable to it.But it might not be that easy.
  #4
Old May 13th, 2005, 08:56 PM
OBJ or anyoneHow would they measure the length?My cable from end of the square to the end of the cable was about 14 ft 7 inches when I figure in give or take a little because I cut it off behind the cable bolt that screw into the sleeve and I figure that was about a foot there I forgot to add that part.So I would think I should measure from the gear to the end of the cable? What do you think?Better to order long than to short.
  #5
Old May 13th, 2005, 09:02 PM
OBJ's Avatar
OBJ OBJ is offline
You probably have the rack and pinion steering set up. If your not sure what to get, take your rig to a local dealer for some advice and help. Near the engine end of the cable, there should be some a name and length of the cable if it hasn't been worn off. You can use this to get a replacement. Tele-flex makes a bunch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Throttle cable 1980 4.5 evinrude voodoo Johnson & Evinrude Outboards 2 March 12th, 2006 03:01 AM
40 horse evinrude steering cable jdennysgirl Johnson & Evinrude Outboards 2 February 13th, 2006 12:38 PM
Evinrude 60 hp 1980 replace the steering cable MadeCoolCom Johnson & Evinrude Outboards 1 May 13th, 2005 08:46 PM
Steering cable - used for Evinrude 85 and Merc 50 MartyTn Boat Restoration and Building 3 August 21st, 2003 07:02 AM
Steering Cable. How to disconnect? Evinrude 88 JSLips Johnson & Evinrude Outboards 1 July 6th, 2002 10:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
