i have recently purchased a boat equiped with a 1986 evinrude 25hp and it will not run with out manually choking the dog out of it! i am wondering if there are some breather parts missing? and if that could be my problem?<br />if i put 2 fingers over the inlet to the carb it will run for a few seconds then i remove and it dies? i have found that if i manually (with my fingers) choke off and on it will run prety much indefinitely(but you gotta stay after it with those fingers). it looks to be that there was something bolted on to the carb inlet but i dont know what? i have also replaced the fuel lines and fuel pump. seems not to have made any diffirence. also replaced fuel tank and fittings. <br />just abot ready to pull my hair out!!!<br /><br />breather maybe? and i dont know if it even matters?
