will changing from prop 15x19 to 14.5x25 be better? 3 blade to 4?
letsbarbq
Hello to all. got a long shaft oceanrunner 225 on a big boat. its a wellcraft 25 foot walk around.<br /><br />my goal. --- 1 rpm = 1mph.<br />Lowest RPM, fuel effient, never WOT, 20-30 mph. I dont care about holeshot or fast. Just need to conserve gas tank for long offshore fishing trip.<br /><br />what i got now stainless 3 blade 15x19 cupped little. WOT can be above 5900. rpm is 4000 and i get about 25 mph.<br /><br />Will the rpm be lower and my speed pick up if I goto a 14.5 x 26 pitch? <br /><br />What about if I change to a 4 blade prop with hig pitch. what kind of performance do i get? i read some posting about 4 blade and it has made me confused?<br /><br />any help would be appreciated.
D
DJ
Guest
Re: will changing from prop 15x19 to 14.5x25 be better? 3 blade to 4?
BBQ,<br /><br />Long time, no here from. If you're the same person?<br /><br />You're winding that engine up about right (5900).<br /><br />A four blade will, definetely, get you out of the hole quicker and will hold on better in turns.<br /><br />If you're running a 19" pitch now, you can probably do the same with a four blade. You'll lose a few RPM's, but you're in the RPM range.<br /><br />Dhadley will come along, soon, and make me look like an idiot.
WillyBWright
26 is probably way too steep. You'll probably drop to under 5000 if you can even get out of the hole. I can see one on a light bassboat, but not a 25 footer.
Dhadley
The guys are right. A 25 will kill everything. Holeshot, top end, mpg and eventually the motor.<br /><br />5900 is perfect for that motor with an average load. The thing now is to concentrate on set up. Yes, a 4 blade should help. But it will run at a higher X dimension. That reduces drag which helps increase efficiency. <br /><br />For some reason your numbers for cruise sound off a bit. 4000 rpm with a 19 should be way more than 25 mph. Now, when you say "WOT can be above 5900" what do you mean? How far above 5900?<br /><br />Whats your top (accurate) speed? At 15% slip you should be in the upper 40's.<br /><br />BTW DJ -- I have a feeling nobody could make you look like an idiot....
Dhadley
Hold on a minute... just read your other post<br />
its gonna be be on a wellcraft 25 foot walk around.
Have you run this motor on the boat or not?
letsbarbq
hey, yes its the same ole me. Got married and had 2 kids since last posting. <br /><br />so it sounds like a 4 blade, smaller diameter 23 pitch? might help?<br /><br />yeah, i can rev it to bout 6300 rpm, isnt that high?<br /><br />sorry, mistype. it is on boat. and rpm at 4000 cruise the boat at only 25 mphs.<br /><br />would a smaller prop. higher pitch help? or is the boat just to big for a johnson 225. i am hoping i haven't prop correctly thats all.
letsbarbq
o yeah, glad to see that the website and all familiar names are still around.
walleyehed
You need to stay with a larger diameter prop with the load you have. It's not going to be a speed boat regardless.<br />See what Dhadley thinks, but I think a large, high efficiency 4-blade in a 21 pitch will be a good choice
letsbarbq
I dont want a speed machine. i'm on a offshore boat and most of the time we barely get a nice calm day on the seas so cruising 15-20mph is consider a good day. i just want to lower my rpm at cruising speed. I just want to cruise about 3000 to 3300 rpm and cruise about 25+ mph. <br /><br />would a 14.5 by 21 pitch 4 blade do better?
walleyehed
That would be a good starting point, but please understand you must still prop for 5800-5900 max. your cruise will likely be closer to 3500-3700 for max efficiency, but again, this only works if proped for the high-end RPM.<br />If you over-prop, the throttle plates are wide open at your lower RPM, which equals pi$$-poor fuel economy.
fireman57
Married, 2 kids, and still have a boat much less time to use it? You're doing something right.
letsbarbq
hey fireman57 --<br />its alot easier when you get them involved<br />you're right, i need to go home and thank her
