1993 150 Evinrude Sea Pro model - EXETG
robkrl
I was looking for the original prop dimensions for this motor. It now is running a 15.5 x 14 pitch. The motor is on a 20' cuddy Key West. I have not put the boat in the water yet. Just purchased the boat. Also is this a reliable motor?
OBJ
Re: 1993 150 Evinrude Sea Pro model - EXETG
Welcome to iboats Rob!<br /><br />For the "big" engines, there is not an "original" prop size. The engines are proped for the craft they are mounted on. Proping will entail several things like, WOT rpm (which is really the most important), hole shot and best all around use if your not into speed or special purpose.<br /><br />How the engine is mounted on the rig is important also. Too low and the engine is sluggish and won't perform worth a crap. Too high and you'll cavitate at high rpm. <br /><br />If your not sure about all these things, take it to a trusted dealership and let them rig it for you. I'm also sure some of the other guys on the forum will also give you good advice.<br /><br />Thanks for posting.
