bulb assembly for system check tach?
jgrisham02633
Anyone know where I can get just the bulb and housing that plugs into the back of a sys check tach? Is the housing a standard electrical part like those used in car dashboards and such?
dolluper
Re: bulb assembly for system check tach?
take it out and match it 12Volt
angus63
If it's OMC/Bombardier, Give your local dealer a call and see if there is a separate part # for it. If not, you could ask nicely if he has any fried tachs around that you could "borrow" the bulb assembly from.
