Gearcase oil 64' starflite 90
english 79
Does anybody know where i can get hold of some Type 'c' or Premium Blend gearcase oil? I cant find any anywhere!!<br /><br /><br />Cheers....................English
alden135
Re: Gearcase oil 64' starflite 90
Every marina I've been to here in New Hampshire has had it in stock. Perhaps you could have some shipped from Ownens Marine in Manchester, NH (603) 622-3000. I don't know what it would cost to ship across the pond though. I have two pints I just purchased from there. "OMC Premium Blend Gear Lube" I think it was around $4 / pint.
english 79
Thanks for getting back to me so quickly, ill let you know if i can get some!!<br /><br /><br />Thanks again
Paul Moir
If that's an electric shift you have English, only use the BRP (Bombardier Recreational Products) or OMC 'Premium Blend'. I belive the 'Type C' name went away a long time ago for OMC.<br />If it's a manual shift, you can use other maker's 80/90W outboard gearcase oil.<br />This is just a warning as many 3rd party lower unit oils advertise themselves as being compatible with 'Type C'
jimmbo
Don't put anything other than OMC Type C or OMC/Bombardier Premium Blend. Anything else will ruin a driveline which is difficult to find parts for
