1985 Evinrude 140 won't idle
cerwin81
I have a 1985 evinrude 140. The engine will run okay out of water, but after idling for several minutes engine loads up with fuel and shuts off. When in the water engine will idle in Neutral, for a short time before loading up with fuel and shutting off, will not idle in gear at all. You have to rev it up and slam it in gear and gas it to keep it from dying. I premix the fuel and oil. Engine runs fine at WOT and mid throttle just a problem with idling. What would be the first thing to look for and check.? I have tried adjusting idle screw but it doesn't really help. Thanks in advance for any input.
Dhadley
Re: 1985 Evinrude 140 won't idle
Welcome!!<br /><br />On a 1985 140 the idle jets meter air. If they are plugged the motor will run very rich at idle. I would start with a good soaking and cleaning of the carbs. Especially it its been sitting a while.<br /><br />Some more info might be helpful. What plugs are you running? Is the fuel fresh (less than 30 days old)?
8up
chad e,<br /><br />The guys on this site are great and will be sure to be alot of help to you. Do you know what your engine idles at in gear, in the water with no load, (when it stays running)? If my memory serves me correct it should be somewhere around 600-700 rpm.
