silenscurator
- Jan 14, 2005
- 86
Well, with the help of several people on here, I've managed to get everything apart that I needed to fix. I even know how to get everything back together, however, I just have a few questions about getting it back together.<br /><br />1. For the past few years, I've been having trouble getting the motor to stop. Now the start button itself works...tested conductivity, so I assume that its the power pack...How hard is it to replace this piece and is it an expensive fix?<br /><br />2. When putting the flywheel on, should I put grease on the shaft before putting the flywheel on and if so, what kind...will axle grease do?<br /><br />3. The flywheel was a pain the the butt to get off, and I can only imagine that it would be the same goin back on...can I use a rubber mallet to "aid" me in gettin it back on?<br /><br />4. The gaskets for the carb...both the resevoir on the bottom and where it attaches to the block...if they are in good condition ie.. not ripped, torn or worn, can I re-use them?<br /><br />5. Is there anything I should be looking for in regards to wear and tear on the inside of the flywheel or the green parts that are under it...I'm think they are the points?? I could be wrong...<br /><br />6. What is the torque on the nut that holds the flywheel on?<br /><br />Any help would be greatly appreciated.
