Re: 1956 Evinrude 18 hp fuel pump vs pressure tank
You can use the fuel by-pass cover off the later 18, 20, 0r 25. The fuel pump bolts direct to this. Use the pump from any of the above motors. There is enough room under your engine cover to do this. Unscrew the nipple from the intake manifold, this is what pumps air to your 2 line tank, screw in a 1/8" pipe plug. The single line connector will bolt right up where the 2 line connector is. The trouble with the pressure tank is that if you forget to unscrew the pressure cap when not in use, and the hose leaks, or breaks, "and it will" you could have gas every where. If it's your unlucky day it will be the the garage. If real unlucky, an attached garage.
