Re: 1956 evinrude
Hi Mike,<br /> Generally, idle issues come from one of two main sources. Either the carb is misadjusted or dirty, or the motor is sucking air somewhere at the crankcase. Either can cause a low speed sneeze due to lean mixture.. If the upper main seal is bad, then you'll be getting a fair amount of oily mess on the armature plate. If the crankcase halves are blowing out, you'll get the oily mess all over the crankcase and block, weeping from that seam. The bottom seal is harder to diagnose. <br /> How is compression on the motor? <br /> When you cleaned the carb, did you blow everything out with compressed air?<br /> The fuel filter should be in the glass sediment strainer on the bottom of the carburetor, unless you've got an electric choke, in which case you might have a glass sediment bowl somewhere else on the motor, likely on the exhaust cover.<br /> 25:1 mix is good. Don't use the original oil (SAE30), but rather make sure you're using modern TC-W3 rated oil...<br />- Scott
