Re: boyesen reeds and rebuild
My number 144 reeds stated enrichening 5 sizes on the idle circut, but you may have a point in 2 sizes for fuel jets vs. air jets.<br />You've got me wondering if I remember right, now.<br />Read it carefully, as the instructions for J/E are different than other manufacturers.<br />Point is, the idle circut HAS to be richer for fiber reeds so you don't have a lean cough-back that can break the reeds.<br />I would install the reeds from day one. You'll see a much more stable idle, increased hole-shot, and a tremendous mid-range acceleration gain, but don't expect much extra on top-end on the 115.<br /><br />EDIT; Make sure you leave the curved reed stop cage out that went with the stock reeds....all you use is the plates that come with the reeds.<br />Believe it or not, I've had these come in with the curved stops put in on top of the fiber reeds....doesn't let them open as they should.
