I just boought a OD green, Military Surplus, extra long shaft 25hp Johnson, Model RDM-14. <br />Some research revealed that it was built in 1953 and used to move barges and combat bridge sections. It's built like a tank with armored spark plugs and wires, etc. The overall construction is heavier than a commercial Johnson, but it is mil-spec. In fact, it weights 140 pounds.<br />I plan to mount this on my Aquarius A-23 sailboat, which can make good use of the extra long shaft.<br />This motor has been stored for decades. I plan on breaking it down partially, cleaning it up and replacing parts like the impellor, points, plugs, carb kit, etc. <br />The prop has a few minor nicks in it and some small bends. It's a 11 x 9, with extra big blades. This would hardly power a speed demon, but it would push a house. As far as repairing the prop, I'm a Master Clockmaker and used to moving metal around and finishing it.<br />My big proplem is, where do I find a shop manual for this vintage Mil Spec motor?<br />In fact, I can't even find a spec sheet or shop manual for a commercial model Johnson 1953 RD-14. I figured 80-90% of the commercial parts will interchange with the Mil-Spec. The armored spark plugs and wires can be replaced with regular ones, etc. I have no intentions of paying $20-25 for NOS armored spark plugs, even if I could find them...Besides newer plugs are much better performing. <br /><br />I still would like to have a shop manual or tech/spec sheet on this motor. I suspect all of the early 1950s Johnson/Evinrude 18-25 hp motors are pretty similiar. I have a 1950's 18hp Evinrude which has a very similiar powerhead. <br />Can anyone point me in the right direction?
