Re: Timing marks
There are timing devices for those magnetos. They're T-bars that go on in place of the flywheel. The breakers should open when the mark on the T-bar lies between two timing marks on the mag plate. Dealers have those. That's the only way of setting the timing that I'm aware of. But if your points are at .020, the timing will be well within in the ballpark.<br /><br />If you want to check the timing with a light, pull the sparkplugs. Find top dead center for the top sparkplug (I usually stick a pencil with the eraser end against the piston for ballparking TDC). Check for what marks line up with what reference. That should get you going.<br /><br />The key isn't so much to set the timing individually, but as a pair. With a feeler gauge all you can do is set them individually. But that doesn't guarantee that the plugs will fire exactly 180 degrees apart. They could both be right at .020 and still be a few degrees off. When timing with the T-bar, it isn't uncommon for one or both sets of points to vary from that by a few thousnadths.<br /><br />What you can do with a timing light is verify that the sparkplugs are firing 180 degrees apart. For that you need to accurately nail-down TDC markings and make another straight across the other side of the flywheel for #2. If they fire a few degrees off you'll have to start playing with points gaps. That'll make the motor run smoothest, but few people would ever notice the difference.
