ouch, while removing the two s/s bolts from the lower unit ,I sheared the head completly off the lower bolt as the bolt shaft has seized .I have little room to drill the remains out as the prop shaft is inclose proximity.I doused the area with anti-seize products but no luck yet.Should the lower unit slide off and if so,is just a bit of force needed to dislodge stuck component
