Hello,<br /><br />I've aquired a 1956 30 HP Johnson. I'm pretty comfortable with the mechanics of it, but I don't know a lot about the electronics on it.<br /><br />1. The boat it came off of doesn't have a key or button to start it. I'm guessing that in 1956, they would just hold the battery cable to the battery until it started and then take it off. Is this a bad guess?<br /><br />2. I think this motor has a 6 volt starter. Will I hurt it by using a 12 volt battery? I've read things that say it's ok to do this.<br /><br />3. I want to wire in a key or button to start the motor from the helm. What guage wire should I use between the starter and the switch?<br /><br />4. This motor hasn't been started in a lot of years. It ran before it was put away but then locked up. It freed up easily with some oil and now turns easily. I'll pour some more oil in the spark plug holes before trying to start it and also change the impeller and the gear case lube before starting it. Anything else I should do before cranking it over?<br /><br />Thanks!
