Re: Does the wax in thermostats lose its temp range?
Tested it tonight several times with a cooking thermometer. Thermometer is probably more accurate than your average temp gauge 'cos precise temps matter more in cooking than gauge ranges of cold / normal / hot / something broke while you weren't watching the gauge.<br /><br />Thermostat opens consistently at 155F and reaches half open if left at 155F.<br /><br />Consistently reaches full open at 160F.<br /><br />So it has a 5 degree range. <br /><br />Book I have says normal operating range for this motor is 130-150F. Over 170F is bad. This thermostat opens 5F past normal operating range and is fully open 10F past it and 10F under limit.<br /><br />More time wasted tinkering but tinkering is educational because now I know:<br /><br />1. The temp range for this motor.<br /><br />2. This thermostat is stuffed<br /><br />3. What the insides of it look like.<br /><br />4. You can get a cooking thermometer at a department store cooking section for about $6 or about the same thing at an auto store for $40.<br /><br />5. The proper cooking temperatures for fats, toffee and so on.<br /><br />6. The stuffed thermostat is worth nothing (unless I put it on eBay) but a new one costs $60.<br /><br />7. I could have saved the $6 on the cooking thermometer, not to mention the time chasing it up and getting it, if I'd listened to OBJ, seahorse, and Fucci, but then I wouldn't be able to cook toffee of different hardenesses as the cooking temp determines the hardness, which isn't something most people know.
