spitfire9au
- Jan 2, 2005
- 19
After shutting down my outboard there's a black gooey oil that slowly seeps from the exhaust, dripping from the centre of the prop. My first thought was gearbox but I'm fairly certain it's not from there. I've replaced the gearbox seals and it still happens. Also the gbox oil is clean, no water and the level stays the same. Over a few days there's probably around 20 or 30 ml leakage. It smells of exhaust and not like gbox oil at all. <br />I'm thinking maybe a blockage in the exhaust causing unburnt oil to accumulate and then gradually seeping out. So far as I can tell the motor runs ok. I have twins and the other motor is clean as a whistle. They're 1984 70hp Evinrudes, premix at 50:1. <br />Anybody have any ideas where I should start checking? <br />Thanks, Jeff.
