ledgefinder
Ensign
- May 2, 2002
- 916
I just got a 1977 70hp triple. Compression was 120/35/120, and the #2 plug might have been too clean. <br /><br />On pulling the head, found that the head gasket was blown (looks "torn") on #2, dead center on the exhaust side. It was an OMC brand gasket, not original, and the head bolts did not feel frankly loose. The motor had been used in salt (wonder how many striped bass it had to it's credit?).<br /><br />Any expert advice here? I am wondering what to do. I am a little leery of just slapping a new head gasket in there and leaving it at that. The cylinder walls, piston tops, and head look fine.<br /><br />I know cylinder #2 is the 'trouble spot' on the triples. I plan on checking the head and cylinder tops for flatness as best I can, and I may take the exhaust box apart to check it for flatness & new gaskets. <br /><br />Anyone who's seen a lot of these have advice on what else I ought to be doing here? I'll certainly clean the carbs, new water pump, etc.. If I sell the motor, I'll probably knock the WOT timing back 2 degrees. Thanks for the help!
