Re: 1987 Johnson 9.9 Keep Fowling the Plugs
As far as the asdjusting knob you mentioned goes - this governs a variable needle for slow running.<br /><br />Warm the motor, screw the needle home (pull the knob off the spinde to do this) and wind it out half a turn. Wait a few seconds for the motor to respond. Keep winding it out a fraction more each time until you hit the most even idle. Then push the knob back on the spindle, making sure it is at its midpoint of travel (pointer on knob straight down) - this gives you maximum adjustment if you need it later.<br /><br />That's the right procedure for the idle knob. On the left of the motor, looking towards the stern from outside the boat, your year should also have a 'trolling' knob. This is just a fast idle adjustment for trolling purposes, and doesn't affect the mixture.
