  #1
Old April 18th, 2005, 09:41 AM
chrisd3 chrisd3 is offline
Default Blown 20A Fuse '97 25HP Evinrude
The fuse next to the power head is blowing when the key is turned on. I've measured a 26A draw. Any idea where the excessive current draw is coming from? All wiring looks good. The engine will still run when jumping solenoid to engage starter. The fuse originally blew when key was turned off while engine was running at a high RPM. Thanks in advance.
  #2
Old April 18th, 2005, 10:02 AM
DJ DJ is offline
Default Re: Blown 20A Fuse '97 25HP Evinrude
Quote:
Truth be known, I'm too cheap to buy the repair manual and too lazy to go to the library...
That's not going to sit well here.
  #3
Old April 18th, 2005, 03:02 PM
reckless reckless is offline
follow the wires and see where they lead to wen the fuse blowsdoes the engine start?
  #4
Old April 18th, 2005, 03:06 PM
Walker Walker is offline
If it blows the fuse immediately when the key is turned on then you have a dead short somewhere. Check all your wiring for a chafed insulation, or you have a wire hooked up wrong somewhere. Check your key switch for any wires touching each other.
  #5
Old April 20th, 2005, 07:07 AM
Vencio and Walker, First thanks for the replies. I'll address both of you here. The engine does start and runs but I have to jump the solenoid with a wire to engage the starter . The key will not start it. The fuse blows when the key is turned to the on position. The wires all look good even the harness leading back to the ignition switch. The boat has never been worked on before, so everything should be plugged in properly. I also checked the neutral safety switch while I was inside the remote control. It's all good.I did get a repair manual and from what I can tell, when the key is turned on, the fuse is in series with the the Power Pack (ignition module). If the power pack is the culprit that's drawing the 26 amps through the fuse, is it possible that the power pack still works? As I said the engine still runs. I don't want to buy another power pack unless I'm certain that's the problem. I did think of simply putting in a 30A fuse....but that's just asking for more trouble.Any insight and thoughts are appreciated!Dean
  #6
Old April 20th, 2005, 07:29 AM
CATransplant's Avatar
CATransplant CATransplant is offline
Don't put a higher value fuse in there. There's a reason that OMC put a 20a fuse in that position. Something's wrong, and a bigger fuse won't fix it.
__________________
Sure...go ahead and laugh at my old aluminum boat. It's paid for!
  #7
Old April 26th, 2005, 06:22 AM
Hi all,To answer my own question, the 20 amp fuse next to the power head is there to protect any accessory that is powered up when the key is turned on. In my case the only thing powered when the key was turned on was the Tachometer. My tach was the culprit. The other thing the fuse is intended to protect is the power trim if so equipped. The fuse has no other purpose but to protect accessories. Moonlit cruises are in the near future!
  #8
Old April 26th, 2005, 09:28 AM
fireman57 fireman57 is offline
Glad you found it. Like they said there is a dead short or an open somewhere and you found it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
blown fuse fishheadny Mercury & Mariner Outboards 2 June 21st, 2006 12:07 AM
blown fuse BILLYP Trailers and Towing 6 April 24th, 2006 05:31 AM
possible fuse blown?? SadReality Electrics, Electronics and Trolling Motors 9 May 31st, 2005 06:41 PM
Blown Fuse Dump Electrics, Electronics and Trolling Motors 3 March 18th, 2005 05:41 PM
Blown Fuse NCOffSeason Boat Topics and Questions (not engine topics) 1 October 23rd, 2003 06:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
