Re: 18 hp gearcase seals
Just think off the enviroment too, oil leaking into the waterways UNNECESSARILY. I too have an old evinrude (1968)with a damaged propshaft (also read, non-replacable in Australia), it cost me AU$40.00 for a local engineering firm to grind it back a few thou, and AU$25.00 for the Speedie Sleeve, to repair the sealing area of the shaft. It has fixed it perfectly. The gear case holds presure and vacumme, and not a drop of oil has leaked out since putting it together.<br />I know that you have just put your's together and painted it, I did that several times, then discovered something else, But I know that it is now done right and hopefully last for many more years to come. I strongly urge you to consider getting it repaired right.
