  #1
Old April 16th, 2005, 04:57 PM
GaryH GaryH is offline
Default 1990 60hp Evinrude stalls
Boat started fine and was running around 3,000 rpm and the motor suddenly stopped running. Tried to start immediately and did not seem like there was any spark at all. After 3-5 minutes motor started and ran well enough to get to a fishing spot. The problem happened about 4 or 5 more times. Sometimes after it died it would start right away, other times, it needed to sit for a few minutes. Seemed like it would only die within the first few minutes of running 2,500-3,000rpm after the engine ran a while seemed to be fine. Carbs have recently been cleaned/rebuilt. Seems like an electrical problem to me. What are the odds it is a power pack problem??Appreciate any help!!!
  #2
Old April 16th, 2005, 07:41 PM
JB's Avatar
JB JB is offline
Default Re: 1990 60hp Evinrude stalls
Howdy, Gary.Welcome to iboats. Sounds like a hot failure in the ignition system. See what happens if you run her with the bonnet off.Most likely suspects are powerpack and stator.Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old June 10th, 2005, 12:45 PM
twoofakind twoofakind is offline
Hello!It sounds like I have the same engine and the same problem! Have you solved it yet?I have been told the powerpack or stator as well. My stator has continuity across the brown leads, so I'm told it's fine. Not sure how to check the powerpack, though.Let me know if you've had any luck! It's a great engine when it's not stalling! By the way, what do you have it on and what RPMs do you get for WOT (wide open throttle)?Thanks!Mick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60hp 1987 evinrude stalls at low rpm & when shifting in gear fab Johnson & Evinrude Outboards 7 May 23rd, 2008 01:12 PM
1990 Evinrude 60 HP Stalls 18RTO Johnson & Evinrude Outboards 2 February 14th, 2006 08:34 AM
1983 60HP Evinrude stalls when put in gear when warm athertop Johnson & Evinrude Outboards 2 September 4th, 2004 01:11 PM
1990 Evinrude 60hp NathanY Johnson & Evinrude Outboards 1 July 26th, 2004 05:28 AM
1990 60HP Evinrude mlcatlopez Johnson & Evinrude Outboards 13 December 12th, 2002 04:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
