Johnson 175 1989
clark123
Help!<br />My motor on my Trim/Tilt burnt out. I have managed to get the engine down as afr as the two stainless steel rams at the bottom. But i cant seem to shift them. Any Ideas?? [/LIST]
OBJ
Re: Johnson 175 1989
Hello Clarky...welcome to iboats!<br /><br />To get the trim rams down, you will have to bleed the fluid off. You can do this by disconnecting the trim line to the trim rams. Messy. <br /><br />Did the motor really burn out or did the brushes just give out?
abc33
Thanks for that job done. Again thanks Clarky.
