  #1
Old April 15th, 2005, 02:09 PM
ky_pits ky_pits is offline
Default 25 hp evinrude stalls
I have a 1974 25 hp evinrude that has had a complete tune-up(plugs,points,carb rebuild,fuel pump)even new coils.The problem is it will start and run fine idling and at full throttle,but after being full throttle for any period of time and you try to idle back down it will die,dead in the water..I can pull and pull but it will fire but die,I wait a while and it will start and run but cuts out unless its full throttle.It acts like it is losing a cylinder sometimes while idling....Any help would be great and yes I have a manual Thanks
  #2
Old April 15th, 2005, 02:22 PM
DJ DJ is offline
Default Re: 25 hp evinrude stalls
Do you have spark, when it won't fire?If so, it could be a plugged circuit in the idle side of the carburetor.
  #3
Old April 15th, 2005, 06:11 PM
Yes i have spark because it will try to hit.Just wont start.If its in the idle circuit then why does it idle fine when i first take it out before it has run full throttle.I dont understand it?It acts like it runs out of gas.I set the float level to specs(parallel to gasket surface)when the carb was rebuilt and all the passages were blown out with air hose.
  #4
Old April 16th, 2005, 04:16 PM
fireman57 fireman57 is offline
You say you have spark because it wants to hit. you may not have spark on both cylinders due to a coil heating up and breaking down. Next time it does this check for a bright blue spark on both plugs. If you have yellow or orange it is not enough. Clean your grounds and connections on them and try again.
  #5
Old April 17th, 2005, 04:05 PM
both coils are new and grounds are clean.It seems to be fuel related,my primer bulb does not stay firm like it should.I have cleaned the carb but maybe missed something.When it does this it acts like its losing a cylinder but dount know why.
  #6
Old April 18th, 2005, 05:05 AM
Consider changing your fuel line. There are orings and check valves in it that may have gone bad. Did you check your float and make sure that you blew all the passages out with air? It only takes a small piece of crud to cause problems.
  #7
Old April 18th, 2005, 10:25 AM
Crappie_Fan Crappie_Fan is offline
I have the same motor and have had similar problems with air leaking into fuel line, where the hose clamps to the bulb. Those cheap crimp clamps that come on the hose are not good enough. This will also help with the bulb getting and staying hard. Just a place to start.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 9.9 stalls when going down from WOT mikeouel Johnson & Evinrude Outboards 2 July 29th, 2005 06:30 AM
4hp evinrude stalls marcleduc Johnson & Evinrude Outboards 5 June 7th, 2004 01:43 PM
Evinrude 140 '85 that stalls. Eebarral Johnson & Evinrude Outboards 1 August 29th, 2002 10:48 AM
78 Evinrude 175 stalls going to WOT wrj9892 Johnson & Evinrude Outboards 5 August 14th, 2002 01:01 PM
Evinrude 88 SPL stalls jbrighton Johnson & Evinrude Outboards 6 October 3rd, 2001 07:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
