  #1
Old August 14th, 2002, 05:52 AM
Luna Sea Luna Sea is offline
Default Aluminum boat owners-zinc HELP!?
Just left my Lund in the salt water for a couple of days. More holes! Thought we had it figured out the first time. Moved the battery, covered it, lifter it up off the floor, ect. (Previous set of holes was on battery side of boat.) Pulled it out yesterday and there’s holes on the other side now. Right where the floor meets the transom. Tying it up next to an old Chris Craft with no zincs, but it’s on a mooring, and there is a portable generator running. My outboard has a bunch of zincs on it but I’m thinking drill a hole (another one) in the transom tonight and add a zinc to the hull. Has anyone else had or heard of a problem like this? Is it zincs? Or is it my boat? About ready to rip all the wiring right out of there……………Becoming very disapointed with the aluminum boat!!!
  #2
Old August 14th, 2002, 09:15 AM
KCLOST KCLOST is offline
Default Re: Aluminum boat owners-zinc HELP!?
When you say holes, do you mean actual holes or the aluminum actually being eaten alive that will lead to holes... Just curious..Something doesn't sound right for you to have bad electrolisis in two days... Especially on the inside of the boat...Did you unhook the batteries? Try that next time and see if any more damage occurs...
  #3
Old August 14th, 2002, 12:16 PM
Small corrosion spots. About 1/8"-1/4" in diameter. And they do go almost through. 2nd time this happened. More JB Weld. Bought a zinc at lunch. Gonna put a couple of studs in the transom. Thought the zincs on the outboard were enough. Unless there's a wire touching the hull somewhere? Or a bad bilge pump? Yes, I need a battery switch too! Leaving tied up to the camp for the weekends causing this? Yeah, couple of days in the salt/electrolytic pond!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Hull - Placing Zinc Block to avoid electrolysis w2much Boat Restoration and Building 7 November 26th, 2006 09:54 AM
aluminum boat... aluminum stringers? diaboy5681 Boat Restoration and Building 6 October 17th, 2006 09:17 AM
Anodes -magnesium?Aluminum? Zinc? summerwind1991 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 6th, 2006 06:28 AM
Zinc chromate and zinc phosphate outdrive primers lenny2113 Boat Topics and Questions (not engine topics) 12 April 15th, 2005 10:56 AM
When do you replace your anodes? Zinc or Aluminum? Homerr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 March 16th, 2005 06:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
