Evinrude 150,, General Question
LGreen6646
1st of all I appreciate any feedback. I just bought a 96 Skeeter with an Evinrude (95) 150 motor. I fired it up, it started and ran fine but no water came from the tell tale port after about 2 minutes of run time I shut it down. I was using a hose flusher on the motor. Is this normal? Does the motor have to heat up first? Should water always come from the tell tale port?<br />Thanks,<br />LGreen
tvpear12
Re: Evinrude 150,, General Question
replace the water pump. yes it should have water from the telltale. watch out for the dirtdobbers if it has been sitting up for very long.
Walker
If you don't know the maintenance history of the motor the by all means replace the water pump. Also check the pisser hose to see if its clogged.
LGreen6646
Thanks guys,I have never dealt with an Evinrude. Someone told that theirs only came on when the engine warmed up.<br />LGreen
Solittle
Water should start comming out almost from the moment it is started. I would also change the thermostats particularly if a salt water motor.
