rforbes1646
- Nov 18, 2004
- 1
I need the head bolt sequence and torque specs for my 1983 75hp johnson 3 cyl. The center spark plug lost threads, and I gotta helicoil it. Was running fine yesterday, suddenly dropped a cylinder - weird. I applied the choke and it picked back up strong for a second or two, then back out. Will run okay at low speed, but won't plane. Checked the fuel pump screen, it's okay. Went to pull the spark plug to check and it came out full of threads from the head. Can't check compression on the center cyl yet, but upper and lower have 140#. Any ideas??
