OK, my Johnson 6hp outboard (1974) runs for about 15min then sputters and dies. After checking fuel (it's new), filters (clean) and spark (great, regapped the plugs just in case), I figured the problem is overheating.<br /><br />I removed the lower unit, cleaned the water pump, replaced the impeller, and resealed everything. After remounting the lower unit, I removed the cap on the powerhead covering the thermostat and water inlet and outlet. My first shock was that a previous owner had removed the thermostat. My second shock was that NO water bubbled out of the inlet when I started the engine.<br /><br />Soooo, I redid the water pump again figuring that I had done something wrong. Same problem, no water circulating in the engine at idle even at high RPM's.<br /><br />What am I missing here? Water flows through the engine when I pour it through, so there's no physical blockage. Any thoughts??<br /><br />AlexL
