  #1
Old July 29th, 2009, 01:25 PM
Maps's Avatar
Maps Maps is offline
Default Problems fueling again
I wasn't able to fill up my third tank this season because of pressure build up in the fuel tank . The 2 first times were already difficult but this time it was impossible .
Blower on , blower off , nozzle up , nozzle down , side ways and 3/4 out . Even wated 10mins with the pistol completly in but same result ; no fuel enters .
I'm trying to inspect the hose vent to see if it's jamed or something but nothing so far . I'm at my last resort wich is the dealer near by...
The guy at the pump told me he had the same problem with 2 other doral boats similar to mine .
The other 2 season's were pretty much the same but I always managed to get some fuel in .
  #2
Old July 29th, 2009, 10:35 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Default Re: Problems fueling again
Venting issues are my only thoughts. If air gets out then fuel gets in.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #3
Old July 30th, 2009, 02:17 AM
Maps's Avatar
I trailered the boat to a gas station before the dealer idea . I was able to fill the tank with no problems what so ever... Go figure ??
So I cleaned the hull + wax and now back in the water and ready to go again he he
Someone told me to use a straw next time at the dock , will see...
  #4
Old July 31st, 2009, 10:43 PM
kenmyfam's Avatar
Keep us posted on your next fill up. Hope all works out for you.
__________________
  #5
Old August 6th, 2009, 11:04 AM
PhatboyC's Avatar
PhatboyC PhatboyC is offline
Yep had this problem too. It happened to me only once this year then I realize why. I usually tank first thing before lowering the boat to much from the lift. This year the only time I had problems was when it was lowered in the water. It was really crazy. Not even half full and gas was overflowing everywhere like a gusher. Now some of the white silicone around the hull has turn yellow.
For some reason when the boat is higher then the fill up tank then no problem. Similar to when you had it on the trailer.
__________________
25'.6" Cuddy Cabin Night on the Hook Boating Day
  #6
Old August 6th, 2009, 09:19 PM
kenmyfam's Avatar
Now that's a strange scenario !!!
__________________
  #7
Old August 9th, 2009, 03:45 PM
Maps's Avatar
I think that the problem is that the air vent is situated to close to the main fuel line . When the boat is in the water the fuel just overspills in the air vent causing pressuere build up . Nothing gets in or out...weird ?
I was told blowing air in the vent using a straw or something works . I'll will try it next time but now I'm still on the same tank .
  #8
Old August 10th, 2009, 11:34 AM
PhatboyC's Avatar
Make sense. Blowing air in the gas vent lines doesn't sound to healthy tho.
This weekend it overflowed a bit during the first 10 gallons even if the boat was high of the water. I just eased up on the gas trigger for the rest and it was fine thereafter.
__________________
  #9
Old August 19th, 2009, 09:46 AM
PhatboyC's Avatar
Just an update. Last weekend I put another 100 liters in and ease up on the gas trigger when filling. It was fine but I could hear the gas in the gas line not flowing through smoothly. It was burping lots of air.
__________________
  #10
Old August 19th, 2009, 07:48 PM
kenmyfam's Avatar
Slow and steady seems to be the way then eh !!
__________________
  #11
Old August 19th, 2009, 10:52 PM
freelancer's Avatar
freelancer freelancer is offline
A fishing buddy and me went through something similar with a 24 parker, worse part about it was that it took about a half an hour to fuel up. 30 minutes of fishing out the window gets old quick. Turns out that it was the screen on the overflow vent, the whole screen was caked up so bad that all the air that went in during fueling had no where to go but back up through the fill. If you have a vent screen, you may want to check it.
__________________
FREELANCER
Its better to push ahead twice than to ever back once!
  #12
Old August 22nd, 2009, 12:52 PM
Maps's Avatar
I tried fueling again after ajusting the vent from the top , same results . I could not fill the tank more than half . But I still havent tried the straw thing yet he he
  #13
Old August 25th, 2009, 03:34 PM
PhatboyC's Avatar
It's obviously a breathing problem. But both our boats are new so I doubt it is clogged. I'm thinking just a bad vent line design from Doral.
Put another 100 liters this weekend while easing on the trigger. No problems.
I'm no where near half hour tho. It used to take me 1 minute per 25 liter jerry cans (6.6 gallons). Now I'm probably at 1 1/2 minutes per can. I usually do 4 at a time so let's say 10 minutes and the cans are stored and the boat is in the water.
__________________
  #14
Old September 24th, 2009, 06:14 PM
plmskier plmskier is offline
Ever call the dealor to find out the fix on the problem?
  #15
Old September 24th, 2009, 10:20 PM
Maps's Avatar
I will mention it when I bring my boat in for winterizing...wich is soon
  #16
Old October 7th, 2009, 02:13 PM
PhatboyC's Avatar
Let me know. Can't wait to see what Poliseno says.
__________________
  #17
Old October 7th, 2009, 07:25 PM
Maps's Avatar
Quote:
mouahaha !
I droped her at the dealer this evening . I'll soon find out what they say .
  #18
Old October 17th, 2009, 05:46 PM
Maps's Avatar
Well got my boat back yesterday from Poliseno . They fished the hole venting system and did not find anything unusual . Guess the problem is the design .
I will try playing with the inlet at the begening of the vent next season . To be continued...
  #19
Old October 17th, 2009, 08:56 PM
kenmyfam's Avatar
Strange eh ????
Any way to add another vent anywhere ??
__________________
  #20
Old October 24th, 2009, 04:33 AM
PhatboyC's Avatar
To bad...but I'm not surprise.
Quote:
Originally Posted by kenmyfam View Post
Strange eh ????
Hum I would have to look again. I don't feel comfortable playing with gas vent lines.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
dockside fueling torcano Boat Topics and Questions (not engine topics) 3 May 19th, 2008 10:30 PM
4.3L EFI Fueling problems Mercruiser ((Help needed)) lukecollins Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 May 15th, 2008 12:41 PM
fueling torcano Boat Topics and Questions (not engine topics) 28 March 18th, 2008 07:32 AM
Didn't want to start after fueling Boat of Us Johnson & Evinrude Outboards 5 July 3rd, 2004 05:57 PM
Fueling up bassher Boat Topics and Questions (not engine topics) 10 June 1st, 2004 05:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
