  #1
Old March 13th, 2009, 12:16 AM
matfalk matfalk is offline
Default Steering Questions
I just bought my first bass boat, a 1989 Stratos 285 PF with a 150 hp Evinrude XP V-6. I got it out on the water for the first time this past Tuesday, and found that the steering is very very stiff. It takes almost everything I have to turn the wheel. I'm assuming that from reading other posts on the forum that I will need to replace the steering cables. It is currently equipped with a Rack and Pinion system, but I've seen recommendations to switch over to a rotary system. How difficult of a job would it be to make this switch? Also, while I'm at it, how difficult would it be to install a fish finder on the bow if there is no wiring already in place for one? The boat only came with a Humminbird LCR 4000 on the console that doesnt work, so I am looking into replacing that one, and adding a second unit to the bow. Thanks for the help guys!
  #2
Old March 13th, 2009, 12:31 AM
mthieme's Avatar
mthieme mthieme is offline
Default Re: Steering Questions
Make sure the rod is greased and not tight through the pivot shaft in the motor.
Nothing wrong with a rack and pinion setup.
Never seen a FF on the bow. Generally, they are easy to mount though. A couple holes, run the cable, mount the transducer and you're in business.
Would swiveling one on the dash be practical?
__________________
Nothing is so broken that Government can't make it worse.
  #3
Old March 13th, 2009, 11:20 AM
I'll check out the rod and make sure of that.
A lot of bass boats feature 2 fish finders, one at the console, and the other on the bow. Reason being that when someone is fishing they can be on the front deck using the trolling motor and not having to turn around to look at the screen on the console. The transducer is going to be easy enough to do, I can put that on the trolling motor, just the power cable I'm worried about.
  #4
Old March 26th, 2009, 05:42 PM
LubeDude's Avatar
LubeDude LubeDude is offline
I have a 1996 295 and I put a finder on the front. There should be a power wire up there on the bow somewhere behind to switch panel!
As to the steering, Turn the motor all the way to the right so that the rod is all the way out, clean it with a solvent so it is spotless, put some light oil or ATF liberally on the shaft and turn the engine all the way the other way. Then back to the right and clean it again. You will have to do this several times. If this does not help, you probably will have to replace the cables.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
More of my steering questions jgaryc3 Mercury & Mariner Outboards 2 August 19th, 2008 11:56 PM
Steering Questions??? skytracker Boat Topics and Questions (not engine topics) 2 April 17th, 2008 11:37 PM
Steering Questions charleso Boat Topics and Questions (not engine topics) 12 December 27th, 2006 02:51 PM
Questions hooking up steering flyinace Johnson & Evinrude Outboards 4 October 30th, 2006 09:06 PM
Steering questions bassinbrunner Boat Topics and Questions (not engine topics) 1 March 23rd, 2004 04:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
