iboats - The #1 Store For Everything Boating
  #1
Old May 7th, 2009, 02:51 PM
varookie varookie is offline
Question setup on 94 stratos 284 fs
Greeting from VA! I just bought a 94 Stratos 284 fs. My friend, who is an avid fisherman and longtime boat owner, went on the test ride with me and suggested that I make some adjustments to the set-up. He suggested that I get a Rapid Jack jack plate. The engine that is on it is a Johnson 150 Fastrike.
The engine height is 5 1/2 inches below the pad. A Stratos tech said that it should be 3 1/2 inches below the pad. I understand that the jack plate will allow me to raise or lower the motor as I need to but what would be an ideal setback for this boat/motor? Any suggestions in the set-up would be greatly appreciated.
Thanks in advance.
  #2
Old May 7th, 2009, 10:33 PM
bhile's Avatar
bhile bhile is offline
Default Re: setup on 94 stratos 284 fs
The anti-cavitation plate should be even with the bottom of the boat. Is that what you are saying is 5 1/2 inches below? Where in Va are you?
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old May 12th, 2009, 06:07 PM
LubeDude's Avatar
LubeDude LubeDude is offline
Quote:
No, Not on a Bass Boat with a Pad!
The measurement should be about 3 1/2" below Pad to start! That means that the center of the propshaft is 3 1/2" from the bottom of the pad with the engine level with the bottom of the boat!
  #4
Old May 15th, 2009, 03:32 PM
Smile Re: setup on 94 stratos 284 fs
Thanks. My friend is encouraging me to raise the motor up to somewhere 1" to 1 1/2"( taken from the bottom of the boat to the center line of the prop shaft which at this point is 5 1/2" to 6"). He thinks that I should get a jack plate to adjust the height and get some setback. What do you suggest? By the way bhile I am from South West VA on the KY line! Very close to some great fishing in North East Tenn.
  #5
Old May 19th, 2009, 02:45 PM
LubeDude's Avatar
A Jack plate will be a plus, but 1 1/2" is going to be too high for sure!
That measurement would be about right if you measure the ventilation plate to the bottom of the boat. The ventilation plate should be about 1-1 1/2" above the bottom! Without a Jack plate thats the best way to measure!
  #6
Old May 21st, 2009, 05:23 PM
Thanks LubeDude. I am going to play around with it and swap some props. I was running a 23 renegade and was only getting 4500 rpm's. I should be getting around 5000 to 5200 rpm's. I think the motor is too low and I had too much prop. I swapped it for a 22 three blade michagan wheel to try this weekend (borrowed from my friend) We will see if it is the motor height or the prop that is dropping the rpm's too low.
  #7
Old May 29th, 2009, 04:45 PM
LubeDude's Avatar
The optimum setup would be to shoot for a WOT full trim, flat out RPM to be in the 5,700-5,800 RPM range. This is because with todays fuels you create a lot of heat with anything below that! Use a stainless prop as aluminum ones do not have enough cup to hold up the bow at high trim levels! You may have to go with a 21 or even a 19! Raker props work well with the Stratos!!! Ebay is the bomb for props, cheap and you can buy try and resell.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stratos Prop Setup...Results So Far... sportpilot Prop Questions and Topics 16 September 26th, 2008 10:57 AM
1994 Stratos 270 FS Nevar Stratos Boats 1 July 19th, 2008 11:27 AM
94 stratos 270 F/s stratoshill Stratos Boats 0 June 1st, 2008 10:41 PM
Stratos 201 FS tbeaze24 Boat Topics and Questions (not engine topics) 1 April 21st, 2008 06:54 AM
Chris Craft 284 Amerosport kman20 Boat Topics and Questions (not engine topics) 0 January 31st, 2004 05:19 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
