  #1
Old June 30th, 2009, 01:15 PM
jasonmiddlebrooks jasonmiddlebrooks is offline
Default What RPM should I run my boat at?
This is probably a loaded question but lets assume just running from point a to point b, not worried about top speed but what is best for the engine. Lets assume calm waters too.
My setup is a Bayliner 2052 Capri Cuddy, 4.3L (262) 185HP, Alpha 1 Gen 2 sterndrive, 19 pitch 3 blade prop. WOT is rated at 4400-4800 RPM.
The other weekend I was running 33-34MPH (not GPS measured) at 4100RPMs.
I assume it is not wise to run the boat at WOT all the time so I am looking for a general rule as to what is the ideal RPMs to run at when running 10-20 miles up and down the lake.
Is there a % of WOT one should run at to get the best life out of your engine? I know inboard/outboard are different than outboards so lets focus on inboard/outboards.
Thanks for any advice/criticism.
  #2
Old July 4th, 2009, 09:10 AM
gcboat gcboat is offline
Default Re: What RPM should I run my boat at?
Hey Jason,
A real quick guide to the "sweet spot" - if you will. Get her up on plane. Trim it out for your optimum running then just start to throttle back. What you're looking for is the boat's ability to stay in that configuration using the least amount of rpm's possible.
Now, the worst thing you could do would be to have the bow really high - that's pushing the boat and extremely hard on the motor ( not to mention your fuel consumption ).
Don't even look at your tach - use your ears. Your motor will tell you when it's happy.
Do remember that with extra weight onboard you will need to push her a little harder to keep on plane. But then again, it's all relevant isn't it ?
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old July 4th, 2009, 03:02 PM
redone4x4's Avatar
redone4x4 redone4x4 is offline
Send a message via Yahoo to redone4x4
I dont know what youre "supposed" to do, but if i know im going on a fairly long ride, Ill keep it around 3500 rpms. ill make short, fast blasts at 4000 rpms and above, but i dont keep it continous like that. I hear people say its fine to run it wide open like that, Im just overly cautious I guess.
__________________
Samuel Adams. Always A Good Decision.
1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
  #4
Old October 21st, 2009, 05:06 PM
express 1 express 1 is offline
optimium rpms for io's is 3000 rpms,for cruising. trim out, adjust throttle to 3000.just don't plow.waste gas.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sun Seeker: RPM what should it run sunseeker Johnson & Evinrude Outboards 1 July 3rd, 2007 10:21 AM
What RPM should my engine run @ WOT? hydro556 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 13th, 2007 11:01 AM
boat will not plane off will not run over 2500 rpm please help jodylee289 Johnson & Evinrude Outboards 7 June 12th, 2007 09:39 PM
4.3 will not run over 3000 RPM mwc951T Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 5th, 2007 06:39 PM
what is proper rpm to run DaveS. Non-Repair Outboard Discussions 12 August 29th, 2003 01:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
