Choke Housing Vented?
myoldboat2
1974 Merc 140 s/n 390xxxx
My choke has the cover plate with a bimetallic coil on the inside. It has the copper riser tube that lets exhaust into the choke housing.
Is the choke housing supposed to be vented? If so, where is the vent? I think mine might be plugged.
original thread here: http://forums.iboats.com/showthread.php?t=351404
(possibly two problems; choke acting weird, engine starting poorly; might be same problem)
Thanks!
KJSmitty
Re: Choke Housing Vented?
I have no idea of your exact setup yet the chock housing isn't "vented" yet rather should have a small vacuum source that pulls the hot air into it. The tube/riser that comes up from your exhaust is not typically pulling exhaust gases - rather just a hot air source etc.
Look for a small vacuum hole within the housing.
Cheers
cr2k
The "vent" is in the part that bolts to the carb. There is a gasket and one or 2 screws that hold the choke housing to the carb body. The carb vacuum pulls the heated air through the housing and past the spring.
myoldboat2
Thanks, found it, the lower left hole. Looks like my gasket was shot.
