Re: Winter..er, Spring build... boat from scratch
I've been thinking about a better way to show off my builds of various things (the boat is just one project... I love building many things, machinery, electronics, etc.) and shareaproject would be better than using my home server's bandwidth (I have a fixed IP www server). But, it would also mean less control. The big thing is, at the moment I need to rebuild my home server with newer software... it's been running uninterrupted for 3-ish years on an older version of Linux. I guess I'll see....
Quick update, again not much to see:
Last night I cut the motor well sides out... these are two pieces of ply the right length to space the last frame (motorwell front) away from the transom, at the right angle to hold the transom in place.
So obviously the spacing between the transom and last frame has to be right, and the last frame has to be braced well enough to hold its own weight and the transom in place for hull assembly.
My case is even more complicated... instead of the stock transom made of 2 3/8 inch ply pieces laminated to a 1 inch dimensional clamp board, I'm using a full height transom laminated to 2 1/2 inches thick. So it's extra, extra heavy.
This is a pic from
another guy's site, the one I linked to above, showing what
HE did for his transom... note that he's using the clamp board and that he's not using the motorwell sides:
http://www.outbackpics.com/Boat/pages/jig/jig4.htm
I'm working on bracing it in place at the right distance, height, level, etc so I can start hull assembly... just like I've been planning to do for weeks.
I could probably get it done tonight and just go with it, but I think I need to adjust the other frames one more time... they're not off by much, maybe a half inch at most, linear distance from the origin (bow). But I'm still being anal about doing things precisely as I can at this point.
Plus as I install the stringers they'll get adjusted anyway. The stringers align the frames because they're slotted at equal distances from the transom. Since my frames are probably not perfectly spaced due to my strongback warping, the stringers will force the hull square. Which is a good thing.
Link to pic on
other guy's site again... his boat looks more impressive than mine
http://www.outbackpics.com/Boat/pages/jig/jig5.htm
At this point I am wishing I'd gone with Marine ply. Not because the ply is a better material for this boat, but because it would warp less, and make this whole process easier. High quality ply plus high quality jig wood means less adjusting for warpage, and less trouble. I'd be much farther along if I didn't have to figure out where an extra 1/4" measurement came from. On the other hand it's forcing me to think, which isn't bad.
I think I'd also use marine ply if I was going to let any of it show. It's much prettier than the HQ exterior stuff.
So, transom mounting then stringers next. Slooooow progress. This is just as hard as doing a boat repair to keep motivated. At this point it doesn't even look like a boat.
But that'll change. I'm enjoying shopping for the accessories I'm going to put on it, doing interior layout, and planning the weird hull add-ons I'm doing.
Erik
