iboats - The #1 Store For Everything Boating
  #1
Old November 6th, 2009, 01:27 AM
jwellcraft jwellcraft is offline
Unhappy 1994 Johnson 150 Tilt/Trim system
Hi, I am having a problem with my trim system leaking down when trimmed up and running. The switches all work fine on the engine and the trim switch on the throttle just when I trim the motor up while running, it goes back down on it's own only if in the water moving. On land tilted up all the way it doesn't move because there is no pressure to pull it down, what could be the problem? And there are no signs of leaks and the fluid level seems to be fine. Also my trim limit switch wires are cut, where do they connect to?
Thanks
  #2
Old November 7th, 2009, 01:38 PM
jonesg jonesg is offline
Default Re: 1994 Johnson 150 Tilt/Trim system
You can get the johnson factory manual for that engine,
www.outboardbooks.com
it dedicates 46 pages to the tilt system alone.
Tilt limit wires go to the limit switch, not sure where the other end goes, I've never followed the harness.
The system might need bleeding.
__________________
I don't read private messages.
Get the genuine factory service manual.
www.marineengines.com
  #3
Old November 7th, 2009, 06:03 PM
Thanks, tried to open the manual realease valve but no luck getting it open. The limit switch wires I know go to the limit switch but the others ends is what I was referring to. I have a Clymer manual for this motor, is that a good one?
  #4
Old November 8th, 2009, 08:06 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you have an o ring leaking, fluid going past it.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old November 8th, 2009, 02:50 PM
Quote:
Nope clymer is confusing. You need the shop manual, its not printed by clymer or anyone else. Its $48 , service manaul, not owners manual.
Use an impact screwdriver on the release valve, tap it with a hammer.
Sears sells impact drivers for less than $25, very handy for outboards.
Or use a big screwdriver, it needs to have a square shaft so you can put a wrench on it. I think its 45lbs torque so expect it to snap loose when you get it.
I'm going home to watch the pats beat the crap out of the dolphins,
I'll snag my shop manaul and look at that wiring diagram.
I'll take a peek at my engine , I have the same yr and HP.
__________________
  #6
Old November 8th, 2009, 06:20 PM
ryoung ryoung is offline
Pull the air box off the front of the motor and look for the blue wires with the white stripe. It might be obvious where they were cut and spliced to bypass the limit switch. If not, you will need to find the blu/wht wire coming out of the tilt relays and break that wire to connect in the limit switch. It would be a good idea to check your limit switch with an ohm meter to make sure it works before you wire it in.
  #7
Old November 8th, 2009, 06:35 PM
Fl_Richard Fl_Richard is offline
Master Chief Petty Officer
9 times our of ten this problem is the manual release valve. Get it unstuck and cycle it a few time, tigten the screw and try it. This has worked for many other people. Get that manual release unstuck!
  #8
Old November 9th, 2009, 10:37 PM
Thanks alot guys, I checked the limit switch and it doesn't work so will get a new one. Yes I will have to get a impact driver but what are the chances of the manual release breaking?
  #9
Old November 10th, 2009, 11:12 AM
It won't break, if you've never used an impact driver try it on a few stuck screws first.
Its in there with 45in lbs, thats kinda tight so make sure it goes back tight.
Very tight.
Only loosen it a couple of turns, its retained anyway.
Loosen it, cycle the system a few times, tighten it again and check fluid level, use a support under the leg. Its a self bleed system.
__________________
  #10
Old November 11th, 2009, 04:10 PM
Got a impact driver but still no luck, I got the type you hit with a hammer on one end and I hit it pretty hard a few times and nothing. The valve head looks pretty old as well and the 2 ears on either side of where you put the big flat head screw driver seems to be opening up a bit now and might break. Guess I might need to drill this out now and use an easy out or should I heat it and try with the impact driver again?
  #11
Old November 11th, 2009, 05:06 PM
I can't imagine any good outcome from using the easy out. You will probably just end up with a broken easy out and metal shavings in the hydraulic system. Maybe spray it with penetrating oil and let it sit overnight and then try a couple more whacks with the impact. It might be worth taking it into the boat shop and let them have a go at it if that fails.
  #12
Old November 11th, 2009, 05:51 PM
Well I sprayed it with Rust check and left it overnight before trying with the impact, might use some other penetrant. I will continue to try before taking it anywhere for someone to just charge me a load of money and tell me it needs to be replaced. Will heating it harm anything else besides the o-rings on the valve? I will replace the valve once I get it out anyway with new o-rings. A dealer told me that loosening this valve was only for tilting the motor manually and this system is self bleeding.
  #13
Old November 12th, 2009, 07:13 PM
I dont think that valve will come out as you loosen it. I think it's captive.
Heat is probably not good down there... Get a screw driver that fits tightly in the slot; this will maximise pressure across the entire screw. If it not a snug fit it will only concentrate it's effort on the edges of the slot helping it to widen.
  #14
Old November 13th, 2009, 11:05 AM
I used a pretty big screwdriver but the head was already strected open. The ears broke off and then I had to drill it and use a screw extractor which moved it a bit until that broke off in there. Now I need a new valve body and valve.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Johnson V4 Non tilt n trim charging system Todesengel Electrics, Electronics and Trolling Motors 0 August 6th, 2009 04:37 PM
Adding OEM Tilt/Trim to 1994 60 HP Johnson richie722 Johnson & Evinrude Outboards 3 August 1st, 2007 09:46 PM
Replace tilt ant trim 1994 Johnson rick3b Johnson & Evinrude Outboards 2 July 9th, 2007 09:15 PM
proper fluid for '99 Johnson 225 tilt and trim system prestridge Johnson & Evinrude Outboards 0 July 15th, 2006 01:04 AM
1994 Johnson Trim & Tilt noisy rattling robalofish Johnson & Evinrude Outboards 3 October 10th, 2005 11:02 AM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
