iboats - The #1 Store For Everything Boating
  #1
Old November 4th, 2009, 09:08 PM
TW1011 TW1011 is offline
Default 90hp Force Problem
First off it's my first boat and I'm not a professional with the mechanic side yet... Well my first problem is, is that when I arrive at the lake, I pump the bulb (which is new) then push the key in to choke it, then try to start it, it usually takes 30 minutes to finally get the thing to start. Once it's started I'll go to push the throttle down to get going and it will usually die.. I can go back and pump the bulb some more while it's idling and then punch it and it will take off and run full speed just fine... I've replaced the fuel line and the spark plugs, as well as cleaned the carbs.. Can someone help me with getting it to start better and not keep dying when I push the throttle in to take off..?
  #2
Old November 5th, 2009, 01:35 AM
jerryjerry05 jerryjerry05 is offline
Default Re: 90hp Force Problem
When you start it do you keep the key pushed in as you turn it over.Just pushing it in without holding it in does nothing.OOPS sorry do a compression test FIRST!!!! Then post the results,they should be equal or close.
When you cleaned the carbs did you clean the mainjet holes with a tip cleaner?Some jets have a small hole that clogs.What did you set the air screw at??J
  #3
Old November 5th, 2009, 03:27 AM
roscoe's Avatar
roscoe roscoe is offline
Check compression and spark.
Starting procedure:
Open fuel tank vent
Check the kill switch, place in "run" position
Squeeze fuel primer bulb till firm.
Advance the throttle 3/4 way, without putting it in gear. -- This is done by either pushing a button in the center of the controls, or pulling the shift handle toward the driver, or raising the fast idle lever, all depending on what control unit you have.
Activate the choke (fuel enrichment valve) by pushing in on the key. The valve is only open while the key is being pushed in.
Turn the key to start while continuing to hold the key in.
Release the key and choke when it starts.
3-5 seconds of "choke", is usually enough.
Be ready to pull the throttle back toward the idle/neutral position, when the engine starts and the revs increase.
Continue to pull the throttle back as the engine warms up.
You should not have to use the choke much, if at all, once the engine has warmed up.
Engine should start within 10 seconds of turning the key.
  #4
Old November 5th, 2009, 07:14 PM
Okay guys, first of I dont know how to do a compression test, so a little help there. I'm a novice with boats rights now but learning.. I got home today and pumped the bulb til firm, put throttle 3/4 way down and choked and kept the key pushed in while trying to start. Got nothing... Not sure where the fuel vent is? Also is there any way that my choke isn't working and is there a way to tell if it's actually choking. Also any more help would be greatly appreciated, I took it to a dealer to work on it a while back and it cost me $600 and never fixed it so I would like to keep from having to take it.
  #5
Old November 6th, 2009, 09:12 AM
Stachi Stachi is offline
Send a message via Yahoo to Stachi
as far as checking if your choke is working,Remove the engine cover and, without trying to start the engine, turn the key to the on position, and push in,...you should hear an audible 'click' from the engine.This means the choke solenoid is activated...push it in and out a few times to see if it works each time...post back and let us know...
__________________
"Good judgement comes from experience, Experience comes from bad judgement"
1990 Bayliner 2002 Capri Cuddy /125 Force " Breaking Wind "
  #6
Old November 6th, 2009, 12:17 PM
I turned the key and pushed it in.. It does make a clicking noise!! Is it possible that the fuel line that is in the motor area that runs to I guess it's the fuel pump and then to the fuel filter.. Would u thank that the line is clogged or something!! Just throwing out ideas!!
  #7
Old November 6th, 2009, 04:23 PM
moparman moparman is offline
do you have any records of service done to the motor?If its firing on all cylinders, then I would look at replacing the fuel pump diaphragm and check valves if they haven't been replaced to your knowledge, that way you know when it was done. This and replacing the water pump impeller generally is considered preventive maintenance,and should be done every two to three years. Keep us posted as to what you find ,it might help others. MOPARMAN ROLL TIDE
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Compression Problem-'90 90HP Force redrooster Force & Chrysler Outboards 8 June 3rd, 2006 10:43 AM
Force 90HP Starting Problem deirdre08 Force & Chrysler Outboards 3 April 2nd, 2006 03:10 PM
Start up (starter?) problem with 90HP FORCE ivan555 Force & Chrysler Outboards 7 June 26th, 2005 07:53 PM
1995 90hp force flooding problem ferg57 Force & Chrysler Outboards 9 May 4th, 2005 06:32 PM
1995 90hp Force charging problem Dan29072 Force & Chrysler Outboards 3 November 6th, 2001 02:44 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
