iboats - The #1 Store For Everything Boating
  #1
Old November 4th, 2009, 09:15 PM
joey maneri's Avatar
joey maneri joey maneri is offline
Default 175 johnson hose problems
i just got a 1981 175 johnson basket case. i assembled the motor to the point where now i have no idea where all the small hoses on the sides of the block and under the carbs go. i cant find any info or diagrams. i think the hoses under the carbs help lube the main bearings, but have no clue what the hoses on the sides of the block are for. (theres like 6 ports on each side of the block). any info would be great.
  #2
Old November 5th, 2009, 06:33 AM
emdsapmgr emdsapmgr is offline
Default Re: 175 johnson hose problems
I believe that on your model, the fuel primer (choke) solenoid injects fuel into the side bypass covers when the choke is applied. So, you have a fuel primer solenoid by the carbs which must be plumbed with tiny hoses and hose tees in order to distribute/inject fuel into the 6 tiny hose barbs on the bypass covers by each cylinder. You can check the factory parts list for the components you need, as they are listed. Also possible that your engine has a recirculation system on it-on this issue, you'd need to check the factory service manual for an exact hose routing for your engine.
  #3
Old November 5th, 2009, 06:56 AM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Check it out here. It may help some. Plug in your year and model and look at the diagrams.
http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #4
Old November 5th, 2009, 06:58 AM
kenmyfam's Avatar
Good tip I use is to take a gazillion digital photos during teardown and keep them till re-assembled again for reference.
Even better tip is having an OEM manual for the motor.
__________________
  #5
Old November 5th, 2009, 08:27 AM
Quote:
do you mean the hoses under the carbs when you say recirculation system? if so i have another set of caebs and intake with all the hoses still on it, but these carbs have the choke tubes connected to the top of the carbs. these carbs i believe are off a vro motor. if i use these carbs i dont know what to do with the ports on the side of the block
  #6
Old November 5th, 2009, 08:34 AM
I wish I had done the teardown! I have a digital camera in my head. Ive been an auto tech for allmost 20 years, this stuff is not my normal thing.
  #7
Old November 5th, 2009, 08:54 AM
jonesg jonesg is offline
Just get the factory manual if you can't get it sorted out,
www.outboardbooks.com
__________________
I don't read private messages.
Get the genuine factory service manual.
www.marineengines.com
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
tilt trim hose problems stillruns Mercury & Mariner Outboards 1 July 25th, 2009 09:53 AM
Fuel Hose- Ball Problems Trashman Johnson & Evinrude Outboards 4 July 3rd, 2006 04:52 PM
Johnson hose clamps?????? Salmonseeker Johnson & Evinrude Outboards 2 June 27th, 2005 04:25 PM
OMC 454 KC belt + exhaust hose problems concept 258 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 September 27th, 2004 10:26 AM
Johnson 8 HP Carb Hose lakeguy72 Johnson & Evinrude Outboards 3 September 13th, 2004 07:04 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
