iboats - The #1 Store For Everything Boating
  #1
Old November 4th, 2009, 11:07 AM
hogginhank hogginhank is offline
Default My max RPM is only 4000???
Well I ran my boat after the fuel pump conversion and it really runs good, BUT the RPM's still don't go above 4000. The compresion is good in all 3 cylinders, it idles perfect and jumps out of the water and I'm at 32 mph and 4000 rpm's without any bogging or anything.
I replaced all the fuel lines with marine grade lines, cleaned out the primer solenoid and everything that has to do with the fuel system so I don't think it is a fuel issue.
I read a LOT of my service manual and some of it is understandable and some of it isn't
My question is can this be a timing issue?? Or a link and sink issue(I'm not really sure how this is done even though I read about it in my manual)
Oh and I had a 19 pitch prop on the motor and switched to my 15 pitch prop and the RPM's still stayed the same..Right about 4050 at the most. This is the same level of RPM's that my boat was running at before the fuel pump took a dump??
Any advice on what to check next on my own before I have to take it in to the boat shop here. My neighbor is a mechanic so he is going to check the timing for me but after that I'm not sure what to do next to trouble shoot the low RPM problem. The motor really seems to be running great except for the rpm's stopping at 4000??
It is a 1995 3 cylinder 50 HP evinrude 2 stroke
  #2
Old November 4th, 2009, 11:18 AM
wilde1j wilde1j is offline
Default Re: My max RPM is only 4000???
Had the motor ever turned 5500 to 6000 RPM?
__________________
Jim
  #3
Old November 4th, 2009, 11:38 AM
When I got the boat the jack plate was all the way up and the prop was barely in the water and would cavitate a little when you turned the boat left or right when on plane(it does have an anti-cavitation plate on the lower unit). It only got to 5100 when it was all the way up. And it only went 29 mph with the 19 pitch prop. I had to take the carbs off and clean them and after that and moving the jack plate down the rpm's would stay around 4500 WOT and the motor would still seem to run good. It would run at about 35 mph and 4500 rpm's with the 19 pitch prop after I lowered the jack plate .
That was all about a year ago. I have been running it a couple times a month for the last number of months and now just recently rebuilt the carbs, new fuel pump and all fuel lines have been replaced as well. New plugs that are gapped per the manual. Fuel tank has all new marine grade fuel line and there are no air leaks and the uplift filter is clean. I have done a lot of back tracking and delt with the fuel issues and there are no issues with any of the fuel getting to the motor. I'm hoping it is a timing issue or something. Especially since when I change my prop 4 pitches the RPM's still don't change??
  #4
Old November 4th, 2009, 12:14 PM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
If you switched from a 19 to a 15 and nothing changed in your tach reading, then I would say your issue is with the tach, not the motor. If this is a 3-cylinder 60 or 70, then a 19 is a lot of pitch for one of them unless you're running a really light performance hull. I run a 17" on my 75hp triple/15-footer and it spins around 5800 RPM at WOT.
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #5
Old November 4th, 2009, 12:57 PM
bkwapisz's Avatar
bkwapisz bkwapisz is offline
Did you try trimming the motor up a little? I know on my big SeaRay I have to start with the drives down to dig out of the hole, and then I trim them up once on plane and have to actually back off the throttle a little as it speeds up and the RPM's increase as the I trim it up towards level. Bottom line is that if the trim is down (bow down) it will strain the motor and the rpms and mph won't be there.
Just a thought FWIW.
  #6
Old November 4th, 2009, 07:48 PM
SKEETR SKEETR is offline
Check the carb butterflies with the engine off. At full throttle are they fully open?
  #7
Old November 4th, 2009, 08:16 PM
yep the butterflies are open and all linked at the same closing/opening point. I tested my tach with my neighbors portable digital tach thing and actually adjusted my tach a while back so I know it is working at lower rpm's..Maybe it is not reading properly at the higher rpm's?? The motor doesn't sound very rapped out at all so I'm pretty sure that it is not reaching the full WOT rpm that it should.
  #8
Old November 4th, 2009, 08:21 PM
Quote:
The boat hull is a 1656 WeldCraft aluminum jon boat hull with a center console and not much else so it is pretty light. I got the higher rpm's when I first got the "used" boat so I am really at a loss trying to figure out why I can't even get to 4500 rpm's even after everything I fixed/replaced is all 100 proof and done right, and better than before??? I sure wish I knew what was going on??
  #9
Old November 4th, 2009, 08:42 PM
Try timing it following the Joe Reeves method found here in the FAQ forum.
  #10
Old November 4th, 2009, 09:23 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
19 inch pitch is huge for that motor in my opinion. You should see a difference with the 15 inch though. How about a photo of the lower unit and the back of the boat ??? (side on)
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #11
Old November 4th, 2009, 09:33 PM
joey maneri's Avatar
joey maneri joey maneri is offline
is your boat kept in thr water? maybe the bottom is getting dirty.
  #12
Old November 4th, 2009, 09:52 PM
I'll check out the timing tip from the faq's thread. No the boat doesn't sit in the water and the lower unit is clean as well as the hull.
Question?? Can the timing be off enough to affect the WOT RPM's that much and it still run good?? Thanks again for all the input..Hank
  #13
Old November 5th, 2009, 12:10 AM
Timing is huge when it comes to max rpm. If yours is off it is probably in the safe zone. What you don't want to do is set it too advanced or you can start melting pistons. The wot timing adjustment will not affect your idle in the least.
  #14
Old November 5th, 2009, 03:17 PM
Quote:
thats good info..
2 questions for you on that note:
Can my timing retard my WOT rpm's 1500 rpm's ??
Will the "Reeves" timing method do what you are syaing and melt my pistons or is it safe to try this setting??
Thanks in advance for any further info..I am going to check the timing tomorrow when I get off of shift to see what I come up with. I will let ya'll know..Adios' for now..Hank
  #15
Old November 5th, 2009, 04:26 PM
It is worth trying. You don't even have to run the engine to check the timing so there is no need to fear. What is important is you have the correct btdc timing number for your motor. As long as you follow the instructions by subtracting 4 degrees from your mark you should be fine.
Will it get you 1500 rpm? I just can't say for sure but it is free to check it out. There is still a possibility you are one hole down. But with your description of how well it runs I have not suggested it as a posibility yet.
My v4 ran pretty damn good on three cylinders, not sure if a 3 cyl would run well on two though.
  #16
Old November 5th, 2009, 09:30 PM
Sounds good. I'm not sure what the btdc stands for(something-timing-something-something?) but I'm sure it's in the service manual I just got from iboats last week so I will check out those pages again. I did read through the section on timing but since I am just a carb rebuilder / impeller replacing level motor mechanic(lol) I will get my mechanic neighbor to guide me through this part with my manual since he has rebuilt/fixed all of my other neighbors outboards for them. You mention "One Hole Down"..Is this refering to the setting on the timing number it's currently at? Thanks again for all your time and expertise on this issue..Hank
  #17
Old November 5th, 2009, 10:27 PM
btdc=before top dead center
By a hole down, I am suggesting that one cylinder may not be firing. At least at high rpm. Usually a failing coil or power pack. Kinda thought my v4 comparison would clear that up
You can check that next once you have established your timing is correct.
  #18
Old November 5th, 2009, 10:29 PM
CharlieB CharlieB is offline
I would be very suspicious of your tach.
A four inch change in prop pitch should have a noticable change in WOT RPM.
To an untrained ear it may not be appearant, but the tach should show the change.
  #19
Old November 6th, 2009, 12:44 AM
I am by no means a mechanic though I have worked on a lot of 25 hp and smaller outboards when I worked at a marina for a few years right out of high school. With that said I tried to listen for a difference in engine sound/rpm at WOT with the 19 and 15 pitch prop and it really didn't sound any different to me. The rpm went from 4000 to maybe 4050 when I put the 15 on it?
What I need to do tomorrow is check the WOT rpm's on my tach with my neighbors portable tach reader "Again" since the last time I checked it was 10 months ago when I initially cleaned out the carbs after they had sat for about 10 months. My tach might have fallen back down in rpms?? It does idle at about 1000 on muffs and about 850 in the water??
Question? Wouldn't I hear if I was one hole down at WOT since I only have 3 cylinders??
Thanks again for all the quick replies..
I just got through reading all the stuff on link and sink and I have that mostly taken care of. My engine idles really well at right between 2.5 and 2.75 turns out on the rich/lean screw and there is no sputter or bogging when I take of or get to WOT so I won't focus too much on that right now. I will have him check my idle timing just to be sure it is within normal limits so I can check that "Check Box" on all of my rule outs..I also read the timing and spark advance and all of those pages (2 times) and I have a better understanding of it so when I assist my neighbor I will know kind of what he is doing. I will keep ya'll posted and I should have a few more question in the next few days..You folks are really awesome..Adios' for now..
By the way, where can I get a tach for my boat that won't break the bank??
  #20
Old November 6th, 2009, 03:59 PM
The 'One hole down' comment is addressing the engine mounting on the boat. Raising or lowering the engine by one hole can have an affect on Holeshot as well as WOT RPM.
I wouldn't go there yet unless you have had the motor off and changed the hight when reinstalling.
If the motor performed when you first got it but now does not then it is an issue yet to be determined.
We just haven't figured out what, yet.
There some great minds here, keep asking questions, and posting answers to our questions, we will get it figured out.
  #21
Old November 7th, 2009, 04:40 AM
jay_merrill's Avatar
jay_merrill jay_merrill is offline
On most boats, any of the OMC triples would not get to 4,100 rpm with a cylinder out, in my opinion. You should also see at least a little increase in rpm, with a 4" pitch change, even if the motor has some sort of issue.
I'm with the "tach gang." I suggest you borrow one, set it for your engine and see what happens.
__________________
I get a lot of PMs, asking for advice on engine problems. Because answering questions in a PM prevents others from sharing in the discussion and learning from it, I would prefer not to receive PMs on these matters. Please post a thread or continue the discussion in an existing thread, so all can benefit from the information. Thanks & happy boating!
  #22
Old November 7th, 2009, 09:02 AM
"I got the higher rpm's when I first got the "used" boat"
Makes me ask another important question.
How much 'stuff' have you loaded into the boat, adding weight that may not have been in it on your first couple of runs?
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
WOT Only 4000 RPM mulliganmagic Prop Questions and Topics 2 June 1st, 2007 12:27 PM
Tach goes from 0 to 4000 rpm deputy00791 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 November 28th, 2005 12:00 PM
Overheat now cannot go over 4000 rpm Mark Kozikowski Yamaha & Suzuki Outboards 1 July 29th, 2004 05:29 AM
SBN 4000 tylerin Dockside Chat 8 October 30th, 2003 05:20 AM
'86 125hp 4000 rpm wot Kcoll Force & Chrysler Outboards 2 August 18th, 2003 06:35 AM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
