iboats - The #1 Store For Everything Boating
  #1
Old November 4th, 2009, 10:41 AM
sidechoke67's Avatar
sidechoke67 sidechoke67 is offline
Default Pegged tach question
OK, for those of you with crystal balls....
My tachometer was a little flakey for all last season...sometimes working, sometimes not (getting no rpm reading at all when it didn't work). On my last trip of the year, and through winterization it was just pegged at 7K while the boat was running. I decided to leave it - finished winterizing my boat and put it away.
Now, my wife is asking me what I want for Christmas. If the tach is shot, I would like to ask her to get me a new one for Christmas. However, I can't really do any testing until the Spring at this point. Money is tight for me these days...I don't want to get other stuff for Christmas, and then confirm that I also need a new tach in the Spring. On the other hand, I don't want us to spend the money on a new tach if I've actually got some other problem.
So...time for the crystal ball...anyone care to offer any guesses on the likelihood that my problem is the tach itself? Anything I can do to test/diagnose without running the boat? My boat is currently winterized in my garage. I looked at the connections behind the tach, and they all look clean and tight.
The motor is a Volvo 3.0L Penta, tach is a Faria, boat is a 2001 Glastron 175.
Thanks for any thoughts/advice!
  #2
Old November 4th, 2009, 10:53 AM
Silvertip Silvertip is offline
Default Re: Pegged tach question
The easiest and most inexpensive thing to do is check connections at the tach and at the engine. The back of the tach has four connections: 1) the internal light which should be lit only when the key is on or the NAV lights are on. 2) Ground. This wire should be daisy chained to the ground wires on the other gauges. 3) +12 volts. This wire also is daisy chained to the +12 volt connection on the other gauges and should be active only when the key is on. 4) Send (S) terminal is the signal from the engine. Since the tach was acting up (on and off) it points to a loose connection. Loose connections can cause the terminals to touch other terminals. The send terminal touching the +12 volt terminal would likely peg the tach. Folks are way to hasty to replace gauges when they are rarely the issue.
  #3
Old November 4th, 2009, 10:59 AM
Knightgang Knightgang is offline
I agree with ST. When I first got my boat, the tach would peg everytime I used it, Then one day, it stopped pegging and worked just fine. I think that was after I replaced the ignition switch... So, I must have hit something under the dash and knocked loose a shorting ground, to bumped a terminal connection back to the right place...
Either way, I bet you issue is somehting simple and does not warrant a new tach...
  #4
Old November 4th, 2009, 05:44 PM
Thanks guys! I will check all my connections...
any idea where, on my engine, I would look for the start of the send signal?
  #5
Old November 4th, 2009, 06:33 PM
Look at the color of the wire on the "S" (send) terminal on the tach. It will likely be the same color at the engine (on the coil).
  #6
Old November 9th, 2009, 12:00 PM
stylesabu stylesabu is offline
yea I would check the wiring. last 2 boats I worked on looked to have been wired by amateurs, wires twisted together, no solder and bare. scotch locks the connect 2 wires together, scotch locks should never be exposed to water or the elements. Mine was going same thing, i tried 2 different tach off ebay, same thing happened with both. looked a little deeper into problem found it to be wiring, 2 wires touching.fixed it and tach works fine, and so did other one.
  #7
Old November 9th, 2009, 12:29 PM
Rocky_Road's Avatar
Rocky_Road Rocky_Road is offline
If it turns out to be your tach, Faria has one of the best customer service departments going! I believe that they will fix (or replace) out-of-warranty gauges for less than the cost of a new one....
If you decide to contact Faria, here are the direct lines to their people:
My name is Jason Blackburn and I am Vice President of Sales and Marketing at the Thomas G. Faria Corporation. Please allow me to confirm that Faria is not closing rather reducing production during the economic downturn. I am a boater myself and understand the often urgent nature of replacing or obtaining technical service on instruments. I have personally serviced and supported the US Marine (all brands) account since 1993 and stand ready to answer any and all calls and other correspondence regarding Faria instruments. That noted, if you need to contact Faria or have any questions whatsoever, please do not hesitate to contact us at any of the phone numbers below:
Jason Blackburn
VP of Sales and Marketing
ph. 860-848-9271 x1212
cell. 860-912-4039
fax. 860-848-2704
email. jasonb@faria-instruments.com
Jessica Goins
Marine Sales Manager
ph. 860-848-9271 x1217
cell. 401-486-2983
email. jessicab@faria-instruments.com
John G. Alexopoulos
Marine Sales Representative (including US Marine, BBG, et al)
ph. 860-848-9271 x1301
cell. 860-608-3257
email. johna@faria-instruments.com
Ted Genard
Customer Service Manager
ph. 800-473-2742
tedg@faria-instruments.com
All the best and Happy Boating!
My very best regards - Jason
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tach pegged with engine off cobra63 Johnson & Evinrude Outboards 12 October 5th, 2009 06:46 AM
tach gauge pegged backwards jdogg#1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 September 21st, 2009 01:58 PM
system check tach pegged daphal144 Electrics, Electronics and Trolling Motors 12 August 19th, 2009 09:52 AM
pegged tach torcano Electrics, Electronics and Trolling Motors 0 April 17th, 2009 12:07 AM
needle pegged on tach. katbird Mercury & Mariner Outboards 1 April 26th, 2004 08:49 AM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
