iboats - The #1 Store For Everything Boating
  #1
Old September 20th, 2009, 01:08 PM
MT Bob's Avatar
MT Bob MT Bob is offline
Default Fuel Gauge Problem - Sender Unit on 2002 Fisherman
Some of you may be interested in a problem I've had with a fuel sending unit on my 1700 Fisherman. Recently I added two cans (32 oz) of Sea Foam to my 26 gal gas tank (2002, Lund 1700), in an effort to help a carburetor problem - per recommendation of a number of Merc. outboard repairmen, and the local Lund dealer.
With a full tank of gas, I took the boat out two days ago and discovered that the fuel gauge read empty. I pulled the floor board and found the tank was full. I pulled the sender (WEMA model UFW 5.5, manuf date 3/13/02) and found that by manually moving the float, the sender was working OK. I then did a series of tests on the float with pure gas, gas diluted with Sea Foam and straight Sea Foam. I think that the Sea Foam lowered the specific gravity of the gasoline and the float was not able to displace its own weight with that additive in the gasoline. The result was that the sender's float apparently sank in the gasoline with Sea Foam added. Evidently this is caused by the plastic material will not floating correctly with a Sea Foam additive.
So, I've decided to purchase a replacement sending unit from WEMA that uses a stainless steel float. I've not received the new float yet, but will follow-up with a post when I get it installed. Hopefully the stainless float will not sink in the gasoline with Sea Foam additive. By the way - WEMA USA is the manufacturer of the sending unit and they have been great to work with, nice folks, good service.
__________________
Montana Bob
"Too Many Lakes, Too Little Time"
Lund 1700 Fisherman, 2002
115 Merc EFI 2002
9.9 Merc 4 stroke 2000
  #2
Old September 20th, 2009, 10:53 PM
bhile's Avatar
bhile bhile is offline
Default Re: Fuel Gauge Problem - Sender Unit on 2002 Fisherman
You just have a defective float. It wasn't the Sea Foam.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old September 30th, 2009, 11:09 PM
MT Bob's Avatar
Quote:
That's what I thought until I talked to the float manufacturer, WEMA. The float is actually made of a solid plastic material. There is no cavity in the float. It appears that the solid plastic design is only slightly lighter than gasoline and, when Sea Foam is added, the specific gravity of the gasoline changes and the float sinks.
I have now received a stainless steel model from WEMA (stainless body and float) and installed it. It works great.
__________________
Montana Bob
115 Merc EFI 2002
  #4
Old October 1st, 2009, 01:41 PM
greenbush future greenbush future is offline
I need to replace my sending unit on my Tyee, 96 what did you have to pay for the new one?
Thanks Dan
  #5
Old October 3rd, 2009, 11:24 PM
ziemann's Avatar
ziemann ziemann is offline
Here is the link for WEMA for those that are looking for the info:
http://www.wemausa.com/index.htm
  #6
Old October 20th, 2009, 10:44 AM
MT Bob's Avatar
Quote:
Thanks Dan
Sorry for the delay - I paid $68 incl shipping for model No. SSS-5.5S
This model has a stainless steel body, shaft and float.
__________________
Montana Bob
115 Merc EFI 2002
  #7
Old October 26th, 2009, 10:50 PM
jpbohney jpbohney is offline
I have a 2003 lund fisherman 1800. Where is the sending unit? What floorboard needs to be removed to find it? thanks
  #8
Old October 27th, 2009, 10:36 AM
Billfo's Avatar
Billfo Billfo is offline
Send a message via MSN to Billfo
Very glad I just read your post. I just had a fuel leak around the sender (bad gasket).(2000 Adventure 1800). When I reinstalled my float level device, now that you mentioned it, my float SANK... Didnt really think about it at the time as the fuel gauge worked fine a few days before.. ! However never the less, I did see the float sink ! yes, I added Seaform for the first time this fall..
I may as well replace it before I reinstall the floor.. Thanks, Bill
__________________
2000 Lund 1800 Fisherman Adventure
2000 Mercury Optimax 135HP
  #9
Old October 27th, 2009, 10:42 AM
Billfo's Avatar
On my 2000 (1800) the tank is under the center section of the floor. The 2' x 6' section with about 16 screws.
Quote:
__________________
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel Gauge Sender Unit jayhawkokie Electrics, Electronics and Trolling Motors 3 March 29th, 2009 06:14 PM
fuel gauge and sender problem igh7070 Electrics, Electronics and Trolling Motors 2 March 23rd, 2008 10:50 AM
Fuel gauge, sending unit problem CJY Boat Topics and Questions (not engine topics) 2 August 7th, 2006 12:45 AM
Fuel Gauge And Sender Problem rickdb1boat Non-Repair Outboard Discussions 3 July 1st, 2002 09:16 AM
Fuel Gauge And Sender Problem rickdb1boat Non-Repair Outboard Discussions 1 July 1st, 2002 07:34 AM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
