iboats - The #1 Store For Everything Boating
  #1
Old March 4th, 2009, 11:43 PM
alumanaut's Avatar
alumanaut alumanaut is offline
Default Does this look like an Alumacraft FD?
Seller calls it an Alumacraft FD with a deck at the bow. Its definitely deep. But I've never seen the splash rail be so going back along the side of the hull high the back two-thirds of the hull. FD experts weigh in if you would. Boat has splash trey across transom.
__________________
Lest we forget.
  #2
Old March 4th, 2009, 11:46 PM
alumanaut's Avatar
Default Re: Does this look like an Alumacraft FD?
I meant to see I've not seen the splash rail along the side of the hull be so high all the way to the back of the boat.
__________________
Lest we forget.
  #3
Old March 5th, 2009, 04:06 PM
super cs super cs is offline
Yep, sure looks like it. Should have the model ID and the serial number stamped in the cast aluminum knee between the transom and the keel.
  #4
Old March 5th, 2009, 05:55 PM
Vintage Aluminum Vintage Aluminum is offline
Camera angles can fool the eye. It looks too deep for an FD (and a C, as well) to my eye. At least one pre-1960--they got a little deeper around 1960 or so. Perhaps a Queen Merrie (18 foot) or Queen 16? Does the boat have decks that run along the top side from bow cover to back? That was a Queen Merrie/Queen 16 feature. But, those boats are definitely not 14 footers as an FD would be. Length/beam measurements, transom height, another couple photos will help--unless of course the knee casting/transom tells the story. Good luck.
  #5
Old March 8th, 2009, 02:56 PM
Shizzy's Avatar
Shizzy Shizzy is offline
Ensign
here is a pic of my 68 FD. yours looks deeper and longer. Mine is 14'
it also sounds like you are describing the "Aqueduct Transom" Mine has it too
__________________
'68 Alumacraft FD, '65 Johnson 6HP "The Sea Monkey"
  #6
Old March 9th, 2009, 11:15 PM
River - Runner River - Runner is offline
With just that picture it's hard for me to say what the boat model is. I agree that the spray rails are higher than would be on a FD model, so I'd say it's not a FD.
Could be a Deep C model as pictured? This isn't me or my boat. The model C also has the Aqueduct transom, a great boat for bigger water.
Also as Shizzy's boat, I have this picture of my 1968 FD Aqueduct transom.
  #7
Old March 9th, 2009, 11:40 PM
alumanaut's Avatar
River - Runner and others,
Are the bow decks on these old Alumacraft FDs and Cs stiff enough to step up on, when stepping ashore or back aboard from shore? Or is the bow to teetery to even try it regardless of strength?
__________________
Lest we forget.
  #8
Old March 9th, 2009, 11:47 PM
Shizzy's Avatar
Ensign
I have slid across mine dozens of times. Im only about 155lbs, but its a pretty stout piece.
__________________
  #9
Old October 2nd, 2009, 10:12 PM
Hey - that's me! At an AOMCI meet in the Thousand Islands a few years ago.
Yep, that's my Deep C. Great boat! Built like a tank. And yes, I can stand on the front deck and jump up and down. The FD's deck will hold me, but I wouldn't jump up and down on it. And that's about 240 pounds.
The Queen Merrie's a whole 'nother game. If the Deep C's a tank, the QM's even more so. Higher sided, wider, heavier.
  #10
Old October 6th, 2009, 05:04 PM
gee cee gee cee is offline
E-mail Alumacraft, and give them the hull# sometimes they can help
  #11
Old October 26th, 2009, 10:02 PM
sandusky sandusky is offline
Could it be a Flying D with some of the interior removed? my son's hull on his Flying D is identical to my FD with the exception of seats , ribs, that run length of the boat and a spray rail that is mounted higher on the side of the hull. good luck, sandusky
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FD-10 Go or no? JG_2-Stroke Johnson & Evinrude Outboards 29 April 12th, 2009 10:27 AM
Alumacraft FD alf1960 Alumacraft Boats 16 March 21st, 2009 05:11 PM
alumacraft FD andyrmilwaukee Boat Restoration and Building 5 September 28th, 2008 01:02 PM
transom on FD andyrmilwaukee Alumacraft Boats 2 September 17th, 2008 12:23 AM
1980 Alumacraft Model FD Specs??? terp4life Boat Topics and Questions (not engine topics) 4 September 13th, 2008 08:45 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
