iboats - The #1 Store For Everything Boating
  #1
Old June 22nd, 2009, 10:58 AM
Jimmill Jimmill is offline
Default 2052 hatch screen?
I have a 2052 and was wondering if there was a screen provided for the cabin hatch when new? It was hot sleeping in the cabin on the lake this weekend and could not keep the hatch open because of the bugs.
Thanks, Jim
  #2
Old August 18th, 2009, 12:04 AM
mole2's Avatar
mole2 mole2 is offline
Default Re: 2052 hatch screen?
When I purchased my 2005 2052 (new) I made sure the dealer supplied the screen. It does not normally come with the boat but must be purchased separately. I guess he figured he didn't want to lose the sale of the boat over what is basically a $5 item (that probably sells for $50!). Of course I hit him with that after we agreed on price.
__________________
2005 Trophy 2052 -
Mercruiser 4.3L FWC and
Extended Hard Top
Click here for pictures of my Trophy 2052
  #3
Old August 25th, 2009, 06:31 AM
RWILLIAMS RWILLIAMS is offline
My 2002 WA didn't have one either so I made one with 1/4 plywood, some fiberglass screen and marine epoxy. I made a cardboard pattern by having my daughter hold a piece of cardboard up from the inside and I traced the opening with the hatch up. Cut out the pattern and checked the fit. Trimmed as necessary. Then traced onto the 1/4 plywood. I then measured 1 & 1/4 inches in from the outside and made another line. I cut on the inside line with a jigsaw and this gave me a frame that would fit into the hatch with a 1 & 1/4 inch wide area to epoxy the insect screen to.
To make gluing the screen to the frame easier I laid out a large plastic bag and the insect screen. Made sure the insect screen was straight and flat. Mixed up the epoxy and put a generous coat on one side of the frame then laid the frame onto the insect screen and let it dry. Once dry, I took a sharp utility knife and cut the insect screen flush with the frame. Applied another coat of epoxy to the whole frame. Sanded the edges as needed to ensure a snug fit and used a small SS screw and nylon pull tab so it could be easily removed.
I know this sounds like a lot of work bit it didn't take but a few hours to complete. I already had all of the materials so it didn't cost me anything but a little time. Plus I got to do a project with my daughter.
  #4
Old September 8th, 2009, 11:33 AM
frankie g's Avatar
frankie g frankie g is offline
Send a message via ICQ to frankie g
nice! could you post some pic's of the screen?
  #5
Old September 8th, 2009, 12:11 PM
I'll try but I'm really computer slow. I can get my daughter to help with that though. Might take a few days.
  #6
Old September 9th, 2009, 09:40 AM
frankie g's Avatar
I'd like to make one for my 23' and pic's would be a help
  #7
Old September 11th, 2009, 10:56 AM
gazelle gazelle is offline
Not sure if it can be done with the 2052, but on my old Starcraft Chieftain we put a screen on the hatch. Instead of making a frame and stretching screen and then having to store the screen and frame we simply used pliable screen with stick on Velcro.
We cut the screen to the hatch size and then added a little extra. To the extra we attached the velcro. Around the hatch we stuck the other half of the velcro. So when we wanted the screen we simply attached the velcro together and when not in use it took up virtually little room to store. We actually did not store it but instead just left it attached.
all told it was probably a $10 project that took 10-15 minutes to make. Then again there must be something wrong with this idea because it was way too cheap and fast to do for being a boat project!
  #8
Old September 13th, 2009, 08:54 AM
Good idea's!
Thanks, Jim
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1992 Bayliner cuddy 2052 capri 2052rider Boat Topics and Questions (not engine topics) 0 June 11th, 2009 02:56 PM
Bayliner 2052 Cuddy jorisjardin Bayliner Boats 4 March 17th, 2006 02:02 PM
rotten hatch...uuhh...engine hatch...need help duece1 Boat Topics and Questions (not engine topics) 0 September 8th, 2003 03:17 PM
Steering problem on 2052 Capri ufm82a Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 30th, 2003 07:23 AM
Screen Size or Screen Resolution? kwk Freshwater Fishing 2 June 6th, 2002 11:09 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
