iboats - The #1 Store For Everything Boating
  #1
Old April 26th, 2008, 08:45 PM
tjchapin tjchapin is offline
Default Azure 188 Elite
Guys,
Not much out on Azure, which is cool as you will not see another on he water. 18' with 220 mercury 14.5 x 19 good for 58moh. Boat handles great, even in chop. overall a blast, dealer service in Marble Falls at Tropical mrine awesome.
  #2
Old July 13th, 2008, 12:27 PM
kabong kabong is offline
Default Re: Azure 188 Elite
I own a 2007 Azure 188 with the 4.3 MPI engine and had to put a 4 blade 19 pitch stainless prop on because this boat is an absolute dog out of the hole. They package this unit with a three blade 18 pitch which is totally wrong. It porpoises at anything under 35 m.p.h. When Azure talks about the HULL truth they should be honest and say that the boat is to heavy in the stern. I think alot of the low speed problems could be solved by moving the fuel cell forward 8 inches or so. You shouldn't have to run at 40 m.p.h. to keep the bow down. It performs excellent at higher speeds but that gets interesting in heavy traffic. I recommend installing Nauticus Smart Tabs on the stern (I did yesterday) and you will be shocked at the transformation. Incredible hole shot, absolutely no porpoising, and you can stay on plane as low as 19 m.p.h. It also stopped the stern wag at no wake speeds. With the trim tabs and stainless prop this boat is a dream. I think Azure owes me $700 back.
  #3
Old July 20th, 2008, 12:11 PM
Has anyone else out there had the same experience with their 188 Azure as I had? I assume that the hull problems and balance issues are the same with all 188's. I've noticed that most of the posts in this forum about Azure are about a year old. On the Azure web-site they still are using old pictures and haven't added any new or improved items on the 188. They seem to be focused on the bigger boats in their line.
  #4
Old July 21st, 2008, 12:14 AM
Swishguy Swishguy is offline
I have a solid blue 07 188 Elite. You wanna hear about problems I have had with this boat????
Powersteering rack & pinion replaced
Boat lists badly to the left. Dealer installed bennet trim tabs(warranty nc) & I am still dialing em in
Unbelievable gel coat cracks all over the boat.
The trim tabs got me on plane quicker & got rid of porpoising. Also eliminated the wall of water coming in the back on decelleration
I have a 19 pitch 4 blade stainless prop & can see 51 mph on a great day on gps(4.3 efi)
Dealer will fix gelcoat cracks in the fall. another 1 like mine but all yellow is doing the same thing.
The 20'+ Azures have been dead nutz reliable. my buddy has a 22 deck & it has been bulletproof.
  #5
Old July 22nd, 2008, 12:45 PM
I've heard of the gelcoat cracks but so far I don't have that issue. I can get 54 m.p.h. at 4600 r.p.m. with my 4 blade 19 pitch stainless prop. I installed the Nauticus smart tabs because i didn't want to deal with the pumps and switches of the other types. I also don't have the listing problem either. When the dealer installed your tabs did they ream the start of the mounting hole so the gelcoat doesn't touch the screw? If they didn't, you will probably get a blistering of the gelcoat around the mounting plates. The best example I can think of is trying to screw two sheets of plywood together, when the screw goes through the first sheet it forces the other sheet away until the screw tip gets a bite o the second sheet. I know what you mean about contacting Azure....their support at the factory level totally sucks. I don't see how they were given the J.D. Powers and ***. awards for excellence.......somebody got paid on that deal.
  #6
Old April 5th, 2009, 01:43 PM
Well another boating season is upon us. I haven't seen any feedback from Swishguy after he got his trim tabs set up and if he got his gel coat cracks fixed. I see that Azure put a wrap-around windshield on the new 188's. The boat looks even sharper but I'm willing to bet they STILL have a lousy hole shot and listing problems. Anybody out there with a new 188? I'm curious if they made any improvements to the hull or if they just left the master mold the way it was.
  #7
Old May 12th, 2009, 12:18 AM
Legend73 Legend73 is offline
Default Re: Azure 188 Elite bilge
Hello, I just bought a 2007 Azure 188 Elite and am new to power boats. I have gone through everything and the boat is in great shape. However, I have a question about the bilge pump. The switch lights up when I switch it to manual but I don't hear anything. Does it have a safety switch on the bilge that prevents it from running if there isn't enough water in the bilge? I just want to make sure that everything works on this thing before I throw it in the water. Thanks
  #8
Old May 25th, 2009, 09:18 PM
Hey, the float switch works when the pump is in automatic but when you switch it over to manual the pump should come on and run even if there isn't any water. You should be able to hear it run when you switch it to manual. Did you read the other items about trim tabs and prop configurations? You will want to make those changes too.
  #9
Old June 5th, 2009, 04:33 PM
MI9 MI9 is offline
Hey Guys,
Not sure if anyone is still looking at this thread, but I just found this website and thought I would post on here. I have a yellow 07' 188 Elite and have had the same issue regarding getting out of the hole. I'll be looking at getting the Nauticus Smart Tabs and then possibly changing props. I've also had to situate riders to try and "distribute" the weight properly otherwise it wants to lean. Other than that, I have been pleased with the boat and it looks great on the water. I work in Elkhart where these are made, but haven't needed to contact the factory. I haven't seen any other elites on the water, but have had a lot of compliments. I have the 4.3 Volvo Penta and been real pleased. The one aggrevation I have is fueling. I get back pressure no matter what the fuel level is and find myself having to spend forever trying to fill it up. Anyone else ran into this or have a solution?
Safe riding!
  #10
Old June 5th, 2009, 10:21 PM
Azure bought back all 3 boats the dealer sold. 2 of us had our boats returned to the factory to get re-hulled but by then it was too late. I have purchased a lowe 190 tahiti deck boat. stay away from the azure 188. I have owned 7 boats & my azure had more problems then all the rest combined. The 20' & larger have been great as 2 of my buds bought 22' azure deck boats.
Not gonna miss this boat! Out with the old..in with the new!
  #11
Old June 6th, 2009, 01:54 PM
Hey M19, I fill my boat at the dock mostly and use a 5 gallon jerry can with a small spout so I have space around the filler neck. If I use a gas pump at the station I don't put the spout in very much and I don't have any problems that way. It took me almost 2 hours to get the trim tab mounting brackets measured so the main tabs just miss the inside edge of the mini chines but the actual installation went quickly. Remember....don't let the mounting screws touch the gel coat or your stern will blister because the screws will separate the gel coat from the fiberglass. Also.... only apply the marine adhesive to the top and outside edges of the mounting bracket so any water can drain out the bottom. Good luck.
  #12
Old August 8th, 2009, 12:23 PM
Bearfan85 Bearfan85 is offline
M19,
Did you install the Smart Tabs? I just ran into this forum myself, and I wanted to know if there is any problem installing them with the extended swim platform.
bearfan85
  #13
Old August 9th, 2009, 02:31 PM
Yes I did the installation myself. It took longer to measure where they were supposed to go than the actual drilling. I don't have an extended swimming platform on my 188 so I don't know where the bracing attaches to the stern for the platform. You can reach me at mklev@charter.net if you want pictures of where I installed my tabs. Good luck.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Azure boats Thept Boat Topics and Questions (not engine topics) 4 April 1st, 2008 11:11 AM
Elite Craft Questions chez Boat Topics and Questions (not engine topics) 3 November 29th, 2007 06:04 PM
Who knows Azure Boats? narukami Boat Topics and Questions (not engine topics) 5 September 18th, 2007 09:38 PM
1983 Elite 200 loppster Wellcraft Boats 1 August 2nd, 2006 12:02 AM
Azure elwayfavre25 Boat Topics and Questions (not engine topics) 1 April 12th, 2006 11:46 PM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
