Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2009
    Location
    Front Royal, VA
    Posts
    11
    Default Bayliner 2.3L engine replacement?
    Hey Guys, newbie here.. I'm new to the life of boating. I just bought a 1990 Bayliner with the dreaded 2.3L Ford engine and OMC out drive. The only positive that I've come to find out is that it has a Cobra lower unit. I've read all the posts about this set up so I already know how most of you feel about it but it's mine now and I'll make the best of it. My question is; The engine block is cracked due to the winerization being incorrect or not done. the engine still runs and after using the muffs. everthing sounds good and seems to operate correctly. it's a shame the block is cracked because it fires right up but anyway I have a fresh 2.3L engine out of a 1985 Mustang setting in my garage and I plan on swapping them out starting 3/12/09. are there any secrets of the trade I should know before starting? I've had several projects over the last 20 years as far as building cars and trucks from the ground up so I should easily figure this out. I just wanted to get any helpful hints that can be provided and make sure that the basic auto block was the same as the one in the boat. externally it looks exactly the same. I know that I need to use all the bolt on parts from the boat engine. any help would greatly be appreciated. thank you and happy boating
  2. #2
    Petty Officer 1st Class rjwoodrome's Avatar
    Join Date
    Aug 2008
    Location
    Upstate NY
    Posts
    202
    Default Re: Bayliner 2.3L engine replacement?
    As the senior officers would say Welcome to Iboats.. either the sky is the limit or spare no expense that is up to you. the OMC has been gone 10 years. but there are some aftermarket parts out there. Im wondering is your replacement block the same cast iron or aluminum. and hope you dont have to pay labor. I too have an omc. good luck
    Attached Images Attached Images
  3. #3
    Rear Admiral Howard Sterndrive's Avatar
    Join Date
    Nov 2008
    Location
    Kawarthas
    Posts
    4,220
    Quote Originally Posted by RussellVA View Post
    I think you'll find it pretty straightforward.
    You will want to replace the tin core plugs from the Mustang block with brass ones so they don't rust and leak.
    Get an OMC manual off eBay or somewhere. Seloc in a pinch, Clymer not recommended.
  4. #4
    Banned
    Join Date
    May 2008
    Location
    Manalapan,NJ.
    Posts
    3,597
    Welcome aboard !
    What do you mean by fresh 85' mustang engine ?
    Is it rebuilt ?
  5. #5
    Join Date
    Mar 2009
    Location
    Front Royal, VA
    Posts
    11
    Quote Originally Posted by chiefalen View Post
    Welcome aboard !What do you mean by fresh 85' mustang engine ?Is it rebuilt ?
    "Fresh" meaning I rebuilt it for a friends son. he put less than 4k miles on it then totaled the car. I pulled the engine and it's been setting in my garage for a few months. It was suppose to go in another Mustang but instead he bought a new Ford Focus. He gave me the engine for the time I had in it. I didn't really want it at the time but now it looks like it worked out.
  6. #6
    Banned
    Join Date
    May 2008
    Location
    Manalapan,NJ.
    Posts
    3,597
    It seems your ready to go.
  7. #7
    Join Date
    Mar 2009
    Location
    Front Royal, VA
    Posts
    11
    I have the motor pulled out. peice of cake!!!!! I had it setting on the floor is less the 2 hours. I saw a post where someone painted the engine compartment. pardon my vocabulary, I don't know the boating terms yet. But it's the place the engine goes. my question is where do I get this paint and what is it called?
  8. #8
    Moderator Bondo's Avatar
    Join Date
    Apr 2002
    Location
    The Mouth of the Chaumont River, Ny.
    Posts
    52,755
    Ayuh,.... Rustoleum from your local Hardware Store....
    Any Grease is Better,..... Than No Grease at All.......
  9. #9
    Honorary Moderator Emeritus Don S's Avatar
    Join Date
    Aug 2004
    Location
    Western WA.
    Posts
    62,323
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
  10. #10
    Fleet Admiral HT32BSX115's Avatar
    Join Date
    Dec 2005
    Location
    Left Coast
    Posts
    7,818
    Yes....that would be me. (among others)
    I used Interlux BilgeKote
    Here's some good instructions on it's use
    Bilge Kote is very durable if you follow the directions.
    Cheers,
    Rick
    BEFORE
    AFTER
    73 de Rick
    I use xxx oil and have never had a problem........
    1987 FourWinns 211 Liberator, 7.4L- Bravo III installed by ME,
    Formerly OMG 460 King Kobra powered
    1947 Stinson 108-2 Station Wagon
    , Franklin 6A-335B. Hartzell CS 2-blade prop
    All PM's cheerfully answered! Please ask tech questions in the appropriate forum so everyone's included
Similar Threads
  1. 1987 Bayliner Capri 2.3L OMC Cobra
    By OMC1987 in forum Electrical, Electronics, Audio and Trolling Motors
    Last Post: July 3rd, 2008, 07:27 AM
  2. 1989 Bayliner with 2.3L OMC Sterndrive
    By 2by4 in forum OMC I/O & Inboard Engines & Outdrives
    Last Post: July 8th, 2007, 03:15 PM
  3. engine replacement . on bayliner
    By oleliner in forum Johnson & Evinrude Outboards
    Last Post: December 27th, 2006, 12:22 PM
  4. is it over? 4cyl 2.3L volvo.. 1985 bayliner.. mystery..
    By ac680 in forum Volvo Penta I/O & Inboard Gas Engines & Outdrives
    Last Post: November 11th, 2006, 07:36 PM
  5. is it over? 4cyl 2.3L volvo.. 1985 bayliner.. mystery..
    Last Post: June 29th, 2006, 06:00 AM
  1. iboats Forum Directory - Over 100,000 forum posts organized by topic
